question for exhaust
Old Aug 15, 2008 | 05:23 AM
93maximaguy's Avatar
ok first off this is for a ve30de engine.
second has anyone ever gone to a 3 inch pipe on the exhaust?
and i would like some help in determining the size of my exhaust. a 2 1/2" pipe with one muffler
or...
a 3" pipe with dual side by side 2 1/2" mufflers
or the last option
a 3" pipe with a dual exit one on each side 2 1/2" mufflers like a 350z or g35 setup.
just would like to know what everyone thinks
Old Aug 15, 2008 | 08:43 AM
braxsusriely's Avatar
Exhausted about exhaust
Lotta of threads on this subject already, but i like just running stock except for the WSP Y-pipe.
Here is a recent thread about it
Old Aug 15, 2008 | 12:09 PM
CMax03's Avatar
I personally think 2.25" mandrel bent tubing Is sufficient for our VG30E's, 2.5" is almost to big for a VQ30 which has 4 valve heads that will out flow a VG30E all day!
Old Aug 15, 2008 | 12:28 PM
jdmjunky's Avatar
Anyone running a dual exit on a 3rd gen outta be shot! The only people that should be running dual exit should be the people own 6th and 7th gens!
Old Aug 15, 2008 | 12:30 PM
jdmjunky's Avatar
Get the greddy and call it a day!
Old Aug 15, 2008 | 04:44 PM
sleepyvg30e's Avatar
the goal with exhaust is to get as small as possible without restricting top end power im pretty sure 3" would kill your low end power when a lil bit smaller pipe would do just as good and wouldn't restrict low end or top end power
Old Aug 15, 2008 | 06:10 PM
see thats what i wanted to know. so then a 2.5" single exit it is.
and the reson im not getting a greddy is the fact that im near broke and have access to a welder and some pipe laying around so thanks
Old Aug 15, 2008 | 07:44 PM
burhan92SE's Avatar
why dont u just go to a muffler shop and tell them to make u custom exhaust....i made mine custom....2.5 straight pipes with tuner muffler....sounds mean...check it out...http://www.youtube.com/watch?v=K9Tz9L-5dxo
edit: go ahead for dual but i will say get a muffler like i have...
Old Aug 15, 2008 | 08:27 PM
Pearl93VE's Avatar
I can has?
A lot of people with the full Warpspeed Exhaust (2.5" Mandrel bent, Magnaflow resonator/muffler) Say they lost a lot in low end. I would just say run with a Warpspeed Y-pipe (Superior flex section, mandrel bent, stock o2 location, etc), and keep the rest stock and put a muffler on of your choice, unless you can upgrade to something nice like a greddy catback. Since VG's have more tq. On tap at a lower RPM, You shouldn't see as noticeable of a loss in low end with the full 2.5", but I still think a full 2.25" mandrel bent exhaust, high flow cat, deleted resonator, and a quiet muffler (Maybe 5.5 gen) would be perfect.
Old Aug 15, 2008 | 10:50 PM
Maximahappy22's Avatar
On my drag racing VE i have a custom 2.5" exhaust, with no resonators and a magnaflow single tip muffler.
Sounds amazing and looks almost stock. A little low end loss but the high end power makes up for it. If you ever plan on adding a power adder like n2o or boost then you need at least a 2.5" exhaust.
Alex
Old Aug 16, 2008 | 03:11 PM
Alex
is it a good idea to chop the resonator or can that cause turbulence problems
Old Aug 16, 2008 | 06:06 PM
Cliff Clavin's Avatar
Way out West
I have a full GReddy cat back on mine, but I think 3" exhaust on these cars is overkill unless you have a turbo or supercharger.
If you have a dual outlet exhaust, I think you need to do some cutting on the spare tire well. IIRC, there have been a couple of people with a G35 or 350z dual exhaust set up. It actually looks pretty cool, even though I imagine it has no real power benefit.
Old Aug 16, 2008 | 07:56 PM
maxrell's Avatar
Speaking of exhausts can someone explain to me what is a y pipe and its benefits
Old Aug 16, 2008 | 08:52 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
well our cars have a ypipe no matter what. all it does is join the front 3 cylinders' exhaust to that of the rear 3, and direct it to the back of the car. the WSP ypipe has an improved flow design that reduces turbulence and lets the exhaust flow more freely by the junction being parallel rather than perpendicular.
Old Aug 16, 2008 | 09:06 PM
CMax03's Avatar
I think you're very correct, 2.25" in a good size for the VG. The Pacesetter exhaust is that size. I own a 5.5 gen with a full Cattman exhaust system with a Cattman ypipe( have the Cattman headers but didn't install yet, getting ceramic coating), and a 3rd gen with stock for right now but I will be upgradig to a 2.25" system!
Boy your car is clean!!!!
Old Aug 17, 2008 | 06:12 AM
internetautomar's Avatar
mod or sell?
2.5" straight pipe is too large for a stock VE.
Been There Done That
Old Aug 17, 2008 | 10:37 AM
Pearl93VE's Avatar
I can has?
Yeah, I even think the 2.25" would be ideal for the VE as well. Right now I'm bottlenecking the warpspeed Y into stock cat-back, which in itself seems to have better performance than a straight 2.5". But I'd like to get my catback replaced with 2.25" sometime in the future.
Thanks btw! Can't wait to get that flywheel in.
Maxboy23
Sep 4, 2015 06:04 PM
TheMafia
Sep 4, 2015 08:26 AM
Johnny9595
Sep 3, 2015 05:18 AM
Justin Kroll
Sep 2, 2015 11:06 AM
A32goldylocks
Sep 2, 2015 06:39 AM
