Sounds of Water
Old Aug 24, 2008 | 11:42 AM
majordan's Avatar
Sounds of Water
Has anyone else had a noise that sounds like water trickerling in the car. Sounds like the noise is coming from behind the dashboard. My floorboards are as dry as they can be........I am puzzled
Old Aug 24, 2008 | 02:28 PM
burhan92SE's Avatar
water? r u sure u r not leakin gas lol
Old Aug 24, 2008 | 03:15 PM
bLiNg_ThEoRy's Avatar
you more than likely have a clogged heater core.
Old Aug 24, 2008 | 03:27 PM
internetautomar's Avatar
mod or sell?
Check your coolant level first.
Old Aug 24, 2008 | 06:28 PM
Greeny's Avatar
¯\(°_o)/¯
Air in the cooling system....Bleed bleed bleed.....
Old Aug 24, 2008 | 09:34 PM
CMax03's Avatar
turn on your heater so the coolant can circulate thru the entire system and remove any air bubbles trapped in your heater core! Top off your coolant system and don't forget your water pump lube or Wetwetter!
Old Aug 25, 2008 | 04:10 AM
Vasy's Avatar
Every time after I flushed the cooling system, I heard the same sound. It's air in the cooling system. It always went away after some driving with the heater on high setting. I've since learned not to flush in the summer.
Old Aug 25, 2008 | 04:15 AM
burhan92SE's Avatar
u live in Richmond man? in Vancouver?
Old Aug 25, 2008 | 05:12 AM
Yeah, it could be low coolant or even air in the system. I did have the gurgling/trickling sound once and it turned out that my heater core was clogged up. Could be either, but yeah, I would try getting out trapped air first.
Old Aug 25, 2008 | 07:48 AM
BenStoked's Avatar
Jesus was a Zombie.
Richmond, Va, USA
Old Aug 25, 2008 | 08:44 AM
mrkanda's Avatar
Taking my Maxima to the Max!
I've noticed that same noise, but it's been some time since my car has been out commission for a while and I live in Florida. I did notice that last year when it was cold I would hear that noise and the heater wouldn't get warm/hot. I think it must be air in the heater core from when I flushed the system back when, like the other guys said.
Question, will the heater bleed itself if run on high or, if I remember hearing correctly, do I need to elevate the front end of the car as much as possible and then run the heater so all the air can escape?
Old Oct 27, 2010 | 06:04 PM
maxinout93's Avatar
I had the same problem, but didnt know what it was, Guess thats why my heater core went out like it did.lol
Old Oct 28, 2010 | 04:33 PM
Augustus Maximus's Avatar
Why do you go around reviving old threads...ur a bad man . Sic him Greeny.
Old Oct 30, 2010 | 01:27 AM
maximagician's Avatar
im guess it that noise the heater hose valve on the firewall opening?
Mahmuth
Aug 16, 2024 08:23 PM
Miket2006
Mar 1, 2021 03:55 AM
AaronL
Aug 8, 2020 10:31 AM
Need help
23
Oct 2, 2015 08:56 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
