nissan maxima intake adapter question!
Old Sep 12, 2008 | 11:04 PM
Stwodahorty's Avatar
ive bought this bout a year ago, the description says its heat resistant but over time it got deformed because of the heat from the engine. so now i want to find one thats not made of that abs plastic. this description of this says it fits for 89-94 and 95-99. so the question is this.
does anyone know if this will fit a third gen? :
http://cgi.ebay.com/ebaymotors/ws/eB...MakeTrack=true
please let me know. thanks
Old Sep 12, 2008 | 11:11 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
iirc ours is 3" so i guess that's the same as the 4g? get aluminum. mine sucks and it's plastic and i'll be getting aluminum whenever i have money AND remember i need one...
Old Sep 12, 2008 | 11:25 PM
so itll fit?
Old Sep 12, 2008 | 11:29 PM
burhan92SE's Avatar
i got the aluminum adapter wen i got the CAI....but it wouldn't fit...so i had to customized it...i drilled new holes to match with MAF and cut the round housing inside for better flow...there is a thread about it around here i cannot find it....ya u can order it...it will fit if it wouldn't then drilled ur own holes its easy.....
Old Sep 12, 2008 | 11:33 PM
its gonna stick out a bit tho huh? cuz its square shape compared to the original heatresistant adapter?
Old Sep 12, 2008 | 11:36 PM
burhan92SE's Avatar
is it? i dont see any difference...where u gonna put dis? between maf and CAI rite?
Old Sep 12, 2008 | 11:42 PM
yeah, look at the shape difference.
Old Sep 12, 2008 | 11:43 PM
and
Old Sep 13, 2008 | 01:31 AM
Pearl93VE's Avatar
I can has?
the aluminum one would probably fit, worst case scenario you'd have to use some washers on it if you didn't want to drill new holes. The side of the MAF that this will be attached to is flat so it doesn't really matter what you use as long as the bolt holes are the same and the pipe's are lined up.
Old Sep 14, 2008 | 04:16 PM
thanks alot, thats alot of help, cuz the heat resistant one sucks ***** -_-. says heat resistant and over time its all melted and deformed from the heat of the engine
Old Sep 14, 2008 | 04:33 PM
internetautomar's Avatar
mod or sell?
you could just reuse the one that is in the stock airbox.
Old Sep 14, 2008 | 05:09 PM
but it's... trumpeted..
Old Sep 14, 2008 | 05:14 PM
Greeny's Avatar
¯\(°_o)/¯
A couple of dremel cuts, a pair of pliers, and a hammer can make a useful cone intake adapter from the stock unit.
IIRC, i done this to the wifes maxima intake, i will take a pic tomorrow if i can remember..
Old Sep 14, 2008 | 05:49 PM
mod or sell?
yes it is, but that smooths the airflow going in
Old Sep 14, 2008 | 05:56 PM
wooooooow
ghetto much?
Old Sep 14, 2008 | 07:25 PM
burhan92SE's Avatar
or u could go to junkyard and pull one from there if u wanna keep ur stocky...
Old Sep 14, 2008 | 08:22 PM
i did that when i first took it off, but it looks pretty crappy. its not a perfect circle, looks all deformed once u use pliers to bend it.
Old Sep 14, 2008 | 08:58 PM
Pearl93VE's Avatar
I can has?
If you have an RV store near you. You can go there and find a PVC attachment that is 3.5" that works perfectly (Like mine pictured above) I just drilled a few holes in it and bolted it down and it works perfect. Once the Intake is setup it is really unnoticeable.
$4 and about 10 mins.
Old Sep 15, 2008 | 09:10 AM
Greeny's Avatar
¯\(°_o)/¯
wooooooow
ghetto much?
Ya..
No point in spending a whole lot-o-money on a vg auto
anyhoo, here's the ghetto adapter.
Once the rubber filter neck is tightened down onto the adapter, it makes a good seal.
Old Sep 16, 2008 | 04:21 AM
GAMERA30's Avatar
From: Long Beach, CA is where i live. Queens NYC is always home.
Yo Jay (Stwodahorty).. that adapter will work. I had the same one for my car. Just to let everyone know.. the same adapter for a Z32 300ZX also fits... Before any of this stuff was made for our cars,( way back in da day) I used a Z32 intake on my 92GXE. No fitment issues
Old Sep 16, 2008 | 07:20 PM
thanks dude, purchased it couple days ago just waiting for it to come. pretty glad its not abs heat resistant plastic. aluminum ftw!
Old Sep 17, 2008 | 08:53 AM
Deridex's Avatar
I might be missing something here but is the cone filter actually better than stock? As in more air coming in, longer life-span, or just looks cool?
Old Sep 17, 2008 | 09:01 AM
you'll be like a tenth of a HP and a tenth of a LB/FT but it's for looks and sounds, mostly. Perhaps on a cammed setup, turbo, etc, where airflow is more important, then the flow characteristics would come into play more, but on a slap-it-on HAI, the performance gains are pretty small, if even present. Some people report better MPG with cone vs stock to.
Old Sep 17, 2008 | 09:05 AM
Jeff92se's Avatar
I'm needing a caw
Why does your intake tubing look so small?
Old Sep 17, 2008 | 09:54 AM
Pearl93VE's Avatar
I can has?
It's only 3".
Old Sep 17, 2008 | 10:11 AM
Greeny's Avatar
¯\(°_o)/¯
I think it looks smaller due to the 3 1/2 inch adapter he is using after the maf, i thought the same thing, but after seeing he posted it was 3-n-a half inch, it dawned on me why it looked smaller.
Old Sep 17, 2008 | 11:01 AM
Garf's Avatar
When i bought my intake kit the holes for the metal adapter plate were off by about 1/2" but it's really easy to drill new holes or come up with something to make it work. Don't worry about it.
Old Sep 17, 2008 | 02:07 PM
Jeff92se's Avatar
I'm needing a caw
I didn't think the maf was 3.5" though. I didn't have to use that type of coupler when I made my own CAI.
Old Sep 17, 2008 | 04:10 PM
Greeny's Avatar
¯\(°_o)/¯
Well neither did i I bought a stillen aluminum adapter from an org member shortly after making my jeffy/mrgonad cai. at the time of installation i used a plastic ebay adapter.
I don't know whats going on with pearls adapter, the inside diameter looks to be bigger in than the maf diameter, but not sure.
Old Sep 17, 2008 | 04:40 PM
Pearl93VE's Avatar
I can has?
MAF is 3.5", adapter is 3.5", cuplink connector is 3.5" to 3". Tubing is 3" outside diameter.
Old Sep 17, 2008 | 05:32 PM
Greeny's Avatar
¯\(°_o)/¯
I dunno dude, seems like this setup would create a disruption in the airflow through the intake system. The whole point of doing this type of cai is to completely smooth out the air path to the uim.
Either that or your blinker fluid may be low
Old Sep 17, 2008 | 08:22 PM
Pearl93VE's Avatar
I can has?
Hah, well I just topped off the fluid last night so I know it's not that. As far as the CAI goes, it's a work in progress, as you can see I still don't have a mid-pipe so that alone disrupts the airflow a substantial amount already I'm assuming. When I get a little cash I plan on doing a full 3.5" with the midpipe included. The only reason I went this route is because I had the pipe leftover from my VG; (free)
I did still notice an improvement over stock though, and It still has the same resonance of all other VE CAI's I've heard. (Screaming at the top of every gear) so I'm content right now.
Old Sep 17, 2008 | 10:13 PM
it does not fit. i recieve the package today tried it, it does not fit. BUT!! i tilted it sideways and the hole lines up, only thing about it now is that it is only bulted with 2 screws instead of 4. looks kinda weird but hey it works. -_-
Old Sep 17, 2008 | 10:47 PM
Pearl93VE's Avatar
I can has?
You could always just drill holes so it fits correctly.
Old Sep 17, 2008 | 10:55 PM
dude the thing about the aluminum one i bought, you cant drill holes, because the length of the adapter isnt even long enough -_- or else yea i would drill holes, that was the gay part. but yea it works it just looks weird lol.
ah2002
Mar 9, 2016 01:42 PM
xUNIxPanther
Aug 27, 2015 10:09 PM
District
Aug 15, 2015 08:23 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
