Speed sensor
Old Nov 12, 2001 | 08:30 PM
Drstove's Avatar
Speed sensor
Hey all the maxima gurus how do you know if your speed sensor is going bad ? What kind of symptoms will you experience ?
Old Nov 12, 2001 | 08:46 PM
JDwyer2821's Avatar
Re: Speed sensor
ABS Light wil stay on and ABS will not work!
Old Nov 12, 2001 | 08:50 PM
Drstove's Avatar
Re: Re: Speed sensor
Ok thanks. What about the revolution sensor or detector ?
Old Nov 13, 2001 | 03:21 PM
MadMaxBrent's Avatar
The speed sensor generally either works or it doesn't. If it stops then you not only lose your speedo but your odometer. Intermittent speedo problems (i.e. speedo reads wrong speeds, or is at zero although the odometer still ticks over) are generally related to the speedo unit itself. The PCB goes bad (Dry / partial solder joints) causing problems with the drive circuit for the speedo dial.
Hope this helps.
Brent.
Old Nov 14, 2001 | 12:36 AM
Mikes90GXE
There are two sensors on the automatic trans that detect speed. Brent gave you a great rendition of the speed sensor - speed of the vehicle. You asked about the revolution sensor. The revolution sensor is the second sensor on the auto trans that detects speed - that of the internal trans gear train. This signal goes to the A/T control unit and is used in computing shift points along with the throttle position sensor, fluid temperature sensor, A/T mode switch, and the vehicle speed sensor, and some signals that come from the engine control unit.
Old Nov 14, 2001 | 11:28 AM
Quite right Mike. Missed the question about the revolution sensor.
Brent.
ac max 92
Sep 17, 2015 07:35 AM
Djsmaxima
Sep 14, 2015 11:58 PM
Maxxx10
Sep 13, 2015 03:16 PM
I<3 A32's
Sep 10, 2015 11:07 AM
sdotcarter
Sep 2, 2015 09:53 PM
