Heater Core
Old Dec 24, 2008 | 02:17 PM
1993maximaTAG's Avatar
Heater Core
Would this be a bad heater core. I have to tap(hit) on my heater core to get my heater to work and kick on. So, could it be that my heater core is going bad or what could the problem be.
Old Dec 24, 2008 | 02:24 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
how exactly are you hitting your heater core? it's pretty darn well covered up.... what are you actually hitting?
Old Dec 24, 2008 | 02:27 PM
akurtzer57's Avatar
Bet your hitting the fan under dash on passenger side.
Old Dec 24, 2008 | 02:50 PM
internetautomar's Avatar
mod or sell?
time for a new blower motor.
if you are handy you can sometimes fix a bad one by drilling into the end and spraying WD40 into there.
Old Dec 24, 2008 | 06:26 PM
burhan92SE's Avatar
i used to hit on my dash to make my blower motor run and one day it didnt come on as i was hitting on the dash...so i ran to the JY and pulled the motor paid 10 buks came home installed and was enjoying my heater and A/C
so time for the new blower motor maximatag
Old Dec 24, 2008 | 07:17 PM
im hitting a black circle thing. now thinking about it it is a blower motor. how hard is it to change one of those.
Old Dec 24, 2008 | 07:20 PM
mod or sell?
if you can see it, you can replace it.
Book time is .8 hrs
Old Dec 24, 2008 | 08:27 PM
Feldman's Avatar
can you hear your your fan not working and then working after you hit it?
a little background for everybody else here 1993maximatag has been having problems with the engine temp going up and down. heater doesnt work when engine temp is high... which sounds to me like air in the cooling system correct?
The link below is his previous cooling system thread
http://forums.maxima.org/3rd-generat...ng-system.html
Old Dec 24, 2008 | 08:32 PM
well it's probably that he needs to bleed the system but also replace the blower motor.
Old Dec 24, 2008 | 08:59 PM
Feldman's Avatar
from what i understand from texting with him he heater works when the engine temp is normal but not when the temp gets high. what i am thinking is happening is air collects in the heater core causing fluid flow issues. I was thinking that when he hits the fan area under the dash it is causing enough vibration to cause the air to migrate elsewhere thus causing the heater to work
Old Dec 25, 2008 | 07:35 AM
mod or sell?
so you are thinking that he is "burping" the system when he hits it?
not the craziest thought I've ever heard.
Old Dec 25, 2008 | 09:00 PM
i am just going to change the blower motor and get cooling system bled
Old Dec 25, 2008 | 11:00 PM
nissanboy's Avatar
Would like to ask for help regarding my Heater Core please call
Old Dec 25, 2008 | 11:08 PM
there was JUST a thread on heatercore replacement within the last month. try searching.
Old Dec 26, 2008 | 11:53 AM
hope I can make it to a jy today and see if I can find a cheap blower motor and change it out today
Old Dec 27, 2008 | 05:47 AM
i changed the blower motor out in the parking lot of a junk yard and works fine so i hope i can get to changing the t-stat today because there is not air in my cooling system the t-stat is stuck open well i will let you all know when the issue is solve and fixed
Apr 16, 2020 05:15 AM
howardis
Dec 11, 2019 06:10 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
RWCreative
Sep 21, 2015 11:01 AM
lrb6805
Sep 18, 2015 07:07 PM
