no heat
Old Dec 27, 2008 | 03:39 PM
bucketheadd's Avatar
no heat
hello again, havent been here in about 6 years but you cant keep me down
anyway, girlfriend has a 93 max and last week the heat quit working
blows cold as hell
i changed the thermostat and still nothing
pretty sure i bled it out good
any thoughts let me know
Old Dec 27, 2008 | 03:46 PM
ramberg's Avatar
GrandPa
blows cold as hell
Get a antifreeze flush. It worked for me.
Old Dec 27, 2008 | 05:15 PM
pmohr's Avatar
No more Maximas...
blows cold as hell
Does the temp gauge show normal temp, or always cold, or what?
Coolant level?
Getting any flow through the heater core?
Does it blow hot air if you rev it up at all? Or while driving?
Last time the cooling system had any maintenance (if ever)?
Old Dec 27, 2008 | 05:39 PM
BenStoked's Avatar
Jesus was a Zombie.
if the coolant is bled, and the t-stat is new, check the vacuum lines for the heater valve int the engine bay.
Old Dec 27, 2008 | 06:22 PM
internetautomar's Avatar
mod or sell?
I've seen the 3rd gen need some serious bleeding depending on how it is done.
took me over 30 minutes to bleed my VE on level ground
Old Dec 27, 2008 | 09:42 PM
burped it a few more times and now im sweating in it
swear i did it good enough the first time, but
Old Dec 28, 2008 | 03:10 AM
CMax03's Avatar
disconnect the heater hoses and run water thru it or air to ensure it's not blocked internally by crud or corrosion
Old Dec 28, 2008 | 07:54 AM
mod or sell?
congrats. these cars are a pain to bleed IMO
Old Dec 28, 2008 | 08:15 AM
alxdagreat1's Avatar
Can you hear the blower fan running when you turn the heater on? A friend of mine just replaced his heater core a couple days ago
tarun900
19
Dec 20, 2021 06:57 PM
Fbana41
Aug 29, 2016 12:18 PM
captchaos
Mar 15, 2016 12:18 PM
Derrick2k2SE
Nov 19, 2015 10:14 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
