Brakes!
Old Mar 13, 2009 | 12:53 PM
  #41
CapedCadaver's Avatar
Call me Wookiee Goldberg
Originally Posted by vgkid
yea i was just thinking of doing that. im going to get the non turbo fronts from the 90 300zx and do the older disks on the back.
haha im glad i got me a 3rd gen
do you already have rear discs? if you do, what you actually need is the calipers and torquemember and pads from the 91+ 3rd gen, then the 86 Z rear rotor. the bracket thing is for the 91+ people. you can keep your ebrake cables (if you already have discs) just look at the last post in the z writeup thread for a how-to on that.
Old Mar 13, 2009 | 01:18 PM
  #42
vgkid's Avatar
i have a 90 with disks. ill look that up on the local craigslist.
wanted to do the full newer 300zx brake swap. i love the nissan on the caliper. and i wanna time attack the car later.
Old Mar 13, 2009 | 01:54 PM
  #43
the complication of converting to true z32 rear brakes far outweighs having the word "nissan" printed on the rear caliper. Hell, you can get some plastic caliper covers on ebay and put Nissan stickers on them. ricer, but if it's the look that you want, do it. the z31 rears will be plenty enough brake for your needs.
for the calipers and stuff.... just look at the partout threads on the max.org classifieds
Old Mar 13, 2009 | 06:11 PM
  #44
vgkid's Avatar
haha yea i have seen those before. not my kind of thing. after thinking about it. i think i will just get the 90 non turbo front setup and the older rear setup
Old Mar 13, 2009 | 08:14 PM
  #45
why specifically 90 nonturbo? something different about them compared to other years or turbo?
Old Mar 13, 2009 | 08:17 PM
  #46
vgkid's Avatar
my guess is that they would be a bit bigger, not really sure.
and i wouldnt want to spend money on brakes that most def dont even fit my car.
Old Mar 13, 2009 | 09:33 PM
  #47
well i'm just trying to understand what made you pull 90n/a out of a hat... why not the 91tt? or the 94n/a? just trying to understand your logic. why would you guess that the 90n/a would be bigger than _____ and what is _____?
Old Mar 14, 2009 | 12:12 PM
  #48
vgkid's Avatar
idk what was going on in my mind. haha
i thought that the 90 n/a would be smaller than the tt sorry for the confusion
would it be a good idea to get the master cylinder off of one too or is the stock one fine?
Old Mar 14, 2009 | 02:57 PM
  #49
stock one is fine. if you took the cyl you'd have to switch lines around because they aren't in the same order as the maxima mcyl. from what i've heard, all 1991 calipers (na or tt) are aluminum. some other years' trims have aluminum too but i know 1991 was aluminum regardless.
Old Mar 14, 2009 | 09:13 PM
  #50
vgkid's Avatar
ok thanks alot. sorry for so many follow up questions
Old May 21, 2009 | 03:16 PM
  #51
NaCL's Avatar
I am using Brembo slotted and Satisfied brake pads, does a real good job.
Old May 21, 2009 | 03:20 PM
  #52
NaCL's Avatar
Also good brake fluid helps a lot. I am using ATE Super Blue that I got a work.
Old May 21, 2009 | 03:21 PM
  #53
how's the pad wear with those rotors? most people say that slotted rotors are all "omg brakepads! om nom nom nom"
Old May 21, 2009 | 06:10 PM
  #54
sleepyvg30e's Avatar
really? brake fluid can make a noticeable difference ive been using any random crap i find at wateva gas station that sells it
Old May 21, 2009 | 06:19 PM
  #55
internetautomar's Avatar
mod or sell?
Fresh fluid helps. different fluids have different boiling points, so if you really heat up your brakes then you want a good fluid.
Old May 21, 2009 | 07:15 PM
  #56
NaCL's Avatar
Not that bad really. I installed this set-up last summer and I still have a lot of pad left.
Old May 21, 2009 | 07:19 PM
  #57
NaCL's Avatar
I dont skimp on brakes or brake fluid.
When I had OE brake fluid, the brakes felt spongy after awhile, but after I started using Super Blue, no such feeling after some hard driving.
Old May 22, 2009 | 07:03 AM
  #58
Matt93SE's Avatar
STFU n00b!
It depends on lots of factors, but yeah, slotted rotors will "cheese-grater" pads to some extent. Usually that only happens when you get the brakes REALLY hot and the pads get soft.
I've run slotted rotors on my track car for years and haven't had problems. the pads last 3-4-5 track events, depending on temperature and track conditions, and I used to get the same life out of them with solid rotors as well.
Old May 22, 2009 | 09:56 AM
  #59
mod or sell?
One shop I know of takes a cut-off wheel and slots the rotors on all brake jobs, they say it stops squeaks.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
