power steering hose leaking
Old Mar 25, 2009 | 09:08 PM
mokylim's Avatar
so i just had my 91 max oil changed and the guy at the shop said that oil was leaking from the power steering hose "moderately" (not sure if thats the only problem there though)..so i asked for a quote and he gave me a $350 quotation of part,labor etc. one thing i know this is a rip off so i opted to get some 2nd opinion from you guys.
also, i talked to one of my buddies and he said just get the parts and hell do it for a mere 120 labor. question is, any1 know any1 website i can look at for replacement or any ideas on the problem cause im having this feeling there could be more than just the hose. thanks guys!
Old Mar 25, 2009 | 09:34 PM
Gunther's Avatar
All the information on power steering hoses that you could possibly ask for:
http://forums.maxima.org/search.php?searchid=328573
Old Mar 25, 2009 | 10:52 PM
1993-VG30E-GXE's Avatar
I think that's a good price, although he probably won't replace all the system parts. For all the parts alone I have priced out $235.73, I'm going to do it myself....but I can't imagine a mechanic billing less than 2 hrs for the PWR Steering pump replacement with the hoses. The rack may even have to be bled - i'm not 100% sure.
Old Mar 26, 2009 | 06:54 AM
kringle03's Avatar
Link no workie....
Old Mar 26, 2009 | 07:14 AM
Greeny's Avatar
¯\(°_o)/¯
Originally Posted by kringle03
Link no workie....
search result links are only good for an hour.
Old Mar 26, 2009 | 08:25 AM
internetautomar's Avatar
mod or sell?
r joo sirus?
anyhow, to the OP try tightening the hose fittings at the ends sometimes the brass washers start to weep for some reason mostly because of age and things rattling loose.
Old Mar 26, 2009 | 08:38 AM
mokylim's Avatar
can u link me a search again since i didnt write down what the search words were.they were very helpful yesterday when i read them
the mechanic did say it was the "black hose" so base on the articles i read on the search im sure its the pressure hose with the foam padding. im gonna drop by kragen and have a look see how much this thing is.thanks to all the guys who replied!
Old Mar 26, 2009 | 08:40 AM
Gunther's Avatar
Go to Search -> advanced then type Power Steering Hose, select the 3rd gen forum, and set how to order search results from most recent to relevancy
Old Mar 26, 2009 | 02:16 PM
Deridex's Avatar
New hose & installation - $350
Several layers of duct tape around the leaking area tightened with a hose clamp - $5
Did that two years ago when my hose started leaking out fluid. There's too much pressure for duct tape alone to seal the leak but with a tightened hose clamp on top it'll stop the leak for good.
Old Mar 26, 2009 | 02:28 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
remind me never to ride in your car
i have an extra high pressure hose that i pulled off with my old pump... the hose is fine, the pump was ****'d tho. joowannit? wonder where the hell i'd find a box to put that thing in... hmm..
Old Mar 27, 2009 | 09:19 AM
crabapple's Avatar
$350 is too high to just replace the hose.
A pressure hose and labor cost me about $140 a year ago.
Old Apr 12, 2009 | 09:07 AM
cduffy's Avatar
Try http://www.courtesyparts.com
the website will give you a good diagram of all the parts you need. find your car and click on genuine Nissan parts
Old Apr 12, 2009 | 09:44 AM
CMax03's Avatar
Hey, jack the car up and find the source of the leak! Could be one of your brass/aluminum crush washers(2ea) that are at each fitting, or a bad or loose hose, you'll never know if you don't look at it yourself! Check with NAPA thier replacement hoses are good and not quite expensive!
Old Apr 12, 2009 | 09:48 AM
1991Maxima1991's Avatar
lol wow ok from personal experiance... the only way to get rid of that leak is to get a new hose... i got a new power steering hose that went from the Rack to the pump from NAPA for like 40 bucks....very easy and cheap fix.....i tried the whole tape and hose clamp thing.... its a high pressure hose clamps and tape WILL NOT WORK!
lowpost99
Oct 26, 2025 06:53 PM
MR2 T'd
Jul 9, 2021 05:06 AM
captchaos
Mar 15, 2016 12:18 PM
aminus21
Sep 12, 2015 04:53 PM
dcam0326
Sep 7, 2015 07:26 AM
