What is causing this squeeling noise? [in the engine]
I uploaded some vids. Not sure if its the belts thats causing it or what. It doesn't sound like belts because it would squeak like that throughout, no matter if the car is warm or cold.
http://www.youtube.com/watch?v=RuGlJiC3eNE
http://www.youtube.com/watch?v=f3X30hbdd_0
thanks everyone
thanks everyone
You might have a bad bearing on your a/c belt tensioner pulley, remove the a/c belt, see if the noise goes away, if not, continue removing each set of accessory belts until you find the issue.
I had that issue last year on a hot day, One of my belts were squeaking so loudly. I sprayed some belt dressing on the belts and found it was coming from the a/c belt. So I just replaced it since it hadn't been replaced before, put the new belt on, and no more squeak. First I took it to a mechanic, who told me that it was the idler pulley, but I already knew what it was. Also, sometimes the belts can be loose and squeal like that.
Alcohol, Tobacco, and Firearms? Yeah they'd prolly do a number on the belts...
but seriously the ATF would just be a diagnostic, if it takes care of the noise you're going to replace the belts anyway, at least I would hope so.
would the ATF cause them to slip, but do so quietly? or would it make them grip better? I'm weary of this method when the far superior method is just taking them off one at a time until the noise goes away.
I was getting the samething and it was water from the water pump gettin on the belts so yeah make sure that your belts dont have water or anything on them and while ur at it check to see if they are old and if u gonna take them off to check dont even put them back on just replace them i just spent $600 on parts for mi engine and waterpump and im still not done so ur gonna have more problems...
As Greeny said already - its prob the tensioner on one of the belts - thats all your videos can make us say.
4 days worth of posts here to find a frigging squeal is ridiculous.
Right, what I mean is theres no cracks or wear and the belts look brand new. The owner only put 20k since 05. I don't know how to remove the belts myself, it might be easy for you but not for me.
What is it you want from this thread then? - a recipe on how to remove the belts or the directions to the nearest mechanic?.
97_GXE
Sep 15, 2015 06:47 AM
ballerchris510
Sep 10, 2015 09:35 PM
