GXE KEYLESS ENTRY TOUCH PAD PROBLEM!
Old Apr 24, 2009 | 05:35 AM
maxinout93's Avatar
MY Keyless entry touch pad has stopped working. It wont light up or beep or respond to anything. It was working for a while as I had to use it to open the driver side door, because the lock does not come up all the way. And because the lock does not come up like it should, when I open the door, the alarm goes off everytime. So since my keyless entry does not work, I am forced to unlock the passenger side door, or either unlock the driverside door along with opening the trunk, so the alarm does'nt go off. Anyone have any suggestions??
Old Apr 24, 2009 | 05:52 AM
Niccos89's Avatar
Have you searched the forums???
Old Apr 24, 2009 | 01:44 PM
Greeny's Avatar
¯\(°_o)/¯
Resolder or replace the door lock timer..
Old Apr 25, 2009 | 03:40 AM
maxinout93's Avatar
HI, where is the door lock timer located?
Old Apr 25, 2009 | 03:50 PM
Greeny's Avatar
¯\(°_o)/¯
Old Apr 25, 2009 | 05:39 PM
1991Maxima1991's Avatar
put a non gxe handle in it and be done...
Old Apr 25, 2009 | 05:46 PM
Greeny's Avatar
¯\(°_o)/¯
yeah ok...spend an hour ripping apart the door/door handle assembly to replace the handle..or spend 10 minutes replacing the door lock timer.
Old Apr 25, 2009 | 07:39 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
that's like telling someone to amputate their arm because of a broken wrist perhaps he wants to keep his keyless entry? i miss mine... still haven't figured how why it doesn't work anymore well actually it's just my power locks that are bad.. keypad still works.
Old Apr 25, 2009 | 08:23 PM
internetautomar's Avatar
mod or sell?
I'd just disconnect the alarm.
Old Apr 26, 2009 | 08:54 AM
i just figured alot of people have problems with the keyless entry and all it is is another electrical problem that you will have to deal with.....with all the electrical in these cars i would want to do away with any electrical componates that i didnt need like the dumb keyless entry. I think it looks stupid to have those buttens on the door handle anyway, just another way for crooks to try and break in, not to mention if you keep trying the passcode and it doesnt work wouldnt that eventually drain your battery???
Old Apr 26, 2009 | 08:55 AM
o and greeny it doesnt take an hour to take the trim panel off roll up the window and take the nuts off the backside of the dorr handle, dissconnect the rod and your done....
Old Apr 26, 2009 | 09:17 AM
Niccos89's Avatar
I'd pay to see a first timer replace the door handle, change the key barrell and put it all back together in under an hour.....seriously, I would.
Old Apr 26, 2009 | 09:20 AM
BenStoked's Avatar
Jesus was a Zombie.
and then there is the other door to do
Old Apr 26, 2009 | 09:43 AM
true true.... But i was giving him benefit of the doubt that maybe he has already takin apart the door trying to find otu what was wrong with the keypad in the first place...so i figured he could find a non keyless entry door handle alot easier and cheaper than he could find the gxe model.....just thinking about cost effectivness, we are talking about 3rd gens here...not porshes...
Old Apr 26, 2009 | 10:11 AM
BenStoked's Avatar
Jesus was a Zombie.
cost effective?
buy more parts, and spend alot of time swapping stuff around to make it work (time + money)
or
pull the dlt, solder it (which most people at least know somebody with an iron), and reinstall it (time only), and you will be done for at least another ten years for the job
Old Apr 26, 2009 | 03:56 PM
Greeny's Avatar
¯\(°_o)/¯
Dude, you're grasping at some really short straws trying to make your argument. First of all, it's almost never the keyless entry pads themselves that fail, they are made quite well..It's almost always the door lock timer that is causing the issues..Second, It would take a "crook" waaay to long to sit there and try 11ndy billion different combination's of numbers to gain access to the car, it's much easier and more common for thieves to just break out the rear triangle glass window, pop the lock, and boom their in, on my maxima, and on your maxima.. Third, drain the battery? do you realize how long it would take to drain a good battery just standing there punching in codes?..ummm quite a while dude..
You give the general public way too much credit, for the novice shadetree that has never taken the door panels off these cars, it will take them at least 5 times as long to replace the door handles vs. just pulling 3-4 screws out of the panel below the steering wheel, 1 or 2 screws and a plug on the DLT..and they actually FIX the problem all together, instead of going around the issue with 3 times the labor..
Old Apr 26, 2009 | 04:47 PM
Ok Mr. Politically Correct you got me, sorry for just making a suggestion.....i think we've beat this thread dead....
Old Apr 26, 2009 | 09:33 PM
maxinout93's Avatar
Ok so the Door lock timer is actually located beneath or behind the lower steering wheel panel? How hard is it to get to? And what do I need to Solder? I do have a soldering iron, or would it be best to just replace the door lock timer with one from the local junkyard?
Old Apr 26, 2009 | 09:37 PM
no guarantees a JY box will work any better than yours. minus whale just fix the problem with this one and know for sure it'll work. just repair any cracked/bad solder joints you find.
Old Apr 26, 2009 | 10:48 PM
Niccos89's Avatar
+1 on what CapedCadaver said, a junkyard box will do exactly what yours has one day. You should be alright with just the iron, however I've found that resoldering joints sometimes is only a quick fix, and you need to drain out the old solder and run fresh solder into the joints for a permanent fix (I found this with my dimming Climate Control display). Most, if not all of the soldering (in terms of interior electronics) on our cars werent performed by human hands, so even if you suck, odds are your soldering will be 10x better and longer lasting.
Old Apr 27, 2009 | 12:37 PM
nitrous360's Avatar
I wish I could just remove the keyless entry. Tired of fixing it.
Old Apr 27, 2009 | 01:21 PM
Greeny's Avatar
¯\(°_o)/¯
Please tell us what keeps breaking? what part are you replacing?
Old Apr 27, 2009 | 02:28 PM
Thats what i woudl do..- . -
Old Apr 27, 2009 | 07:39 PM
BenStoked's Avatar
Jesus was a Zombie.
d00d...
Old Apr 28, 2009 | 02:32 PM
maxinout93's Avatar
Well Guys I have located the door lock timer, after pulling the lower dash panel off. I also stumbled up on the ANti Theft device, which is a nice feature to have. But for the time being I just unplugged it for now, so that i dont have to worry about the alarm going off when I open the driverside door. That solves that problem!! Keyless entry still does not work, but who cares, the only feature I liked about it was the fact of opening the trunk, and letting the windows down in the summer. The screws on the door lock timer seemed as if they were screwd in with lock tight, so I didnt bother to mess with them.
Old May 5, 2009 | 11:04 AM
WERNER1's Avatar
What are some of the most common symptoms of bad solder joints on the Door Lock Timer? I never really used mine to their full potential,..mostly just to lock the doors for the evening
Oh,. if you'll permit me a side question - Would the door lock timer have any effect on the actual Key activated locking/unlocking of all the door locks? ... The reason I ask is that I replaced the power window/lock control on the Drivers side door last year,.. and ever since then the doors will not all unlock when I insert and turn the key anymore ??
Rick
Old May 5, 2009 | 11:40 AM
Garf's Avatar
Rick
yes, the DLT can affect when you use the key to unlock the doors
example: you use your key to unlock the doors and they unlock briefly but then lock again right after
Old May 5, 2009 | 12:11 PM
WERNER1's Avatar
Hmm... well I guess I'll be tearing into that here pretty soon as well.. I changed out the window/lock controls because the passenger side front window would not go down with the drivers side control(s)... now that's working but the lock stuff is all messed up ... I kept wondering if I had knocked one of the connectors loose when I was putting the door pannel back on ... if it's not one thing, it's 10 others
Thanks.
Rick
rnb754
Sep 14, 2015 11:39 PM
flu2000
Sep 14, 2015 12:34 PM
bbsitum
Sep 11, 2015 04:55 PM
videomano
Sep 8, 2015 03:28 PM
Hailstatejig
Sep 2, 2015 06:52 AM
