BTDC How To Be Exact
Guys, is it safe to hold a screwdriver in the sparkplug hole of the VG30E to feel for TDC physically, with flexbar on on crankshaft pulley nut (I guess i'll need a second person)? The instructions for the leakdown test say for some reason to find a little bit before TDC, I can't see how to accurately do that from looking at the distributor. So I figured, is it possible to feel it then back it off slightly.
What do you suggest.
![Wink](https://maxima.org/forums/images/smilies/wink.gif)
The screwdriver method is probably the easiest and only method if you don't have a calibrated dial guage fitted to your crank pulley.
Leak-down tests generally gets done with the rings under the compression stroke mechanically (iow don't go past TDC and then turn it back!), but still on its way to the top so as to prevent (about 15 degrees before TDC for the particular cylinder) the rings sitting in the normally slightly more worn TDC position where the rings generally tend to wear a radial groove in the barrel.
IMO its very close to a waste of time since a well controlled compression test can tell you the same and much more under the actual working conditions of all the mechanical bits involved in creating a chunk of compressed mixture in any given cylinder.
Yeah,.. what is the deal with all the references to leak down test anyway?.. I've read that a lot on here in just the short time I've been lurking around (??) . .. I've sort of come from the school of doing a good compression test on all the cylinders and get an idea of how they relate to each other in terms of performance and wear (??) ...
LVR, if the engine is out on a stand and one is rebuilding it - can the compression tester somehow function then? Update: I bought the compression tester real cheap on sale for 14 bucks. I did the Leakdown tonight when the plenum was back on, and the test seemed to work BUT, here's something I ran into.
With the screw driver method - I couldn't figure out which up movement in the screwdriver is on the compression stroke - is there some way to differentiate?
The feeling with the screwdriver didn't seem to line up with the cap numbers, so I just went by feeling (and ignored the distributor alltogether)....but unsure which was compression stroke so I tested both up movements. Also, when I rotate, if I leave the screwdriver without me holding it and move towards top, the screwdriver can actually get jammed in there, and I have to back it off to get it out or wigle it out. It starts tilting to one side then jams.
The results of my tests were each cylinder ranged from 0% Leakage to 4% Leakage out of 100% Leakage.
When you have the motor open and anything is either suspect or known to be suspect, do the proper thing and attend to it there and then - you simply cannot do better fault finding than actual individualized item inspection and comparison with the FSM design specs
I still don't know what it is you are trying to do with either the compression tester or the leak-down tester - are you tracing a known symptom or are you just farting around?.
I did the Leak-down tonight when the plenum was back on, and the test seemed to work
As for the direction to turn the motor - BTDC on the crank pulley means exactly that - ie - the timing mark on the crank pulley is still on its way to TDC - in general, you need to only turn the motor in that direction to move from BTDC to TDC while following the particular engine's exact firing order - if you do it right, then the compression stroke on any given cylinder (detected by the "screwdriver method") will and must necessarily correspond to the rotor's position in the distributor cap - no 2 ways about it.................... and I can only repeat again what I said in your other thread
The amount of variables playing a role in drawing a sensible conclusion from a leak-down test is simply staggering - not least of all being a decent mechanical knowledge of the particular motor you are dealing with and compression mechanics in general .................... and this is simply not in the realm of the avg home mechanic trying to maintain/troubleshoot a 15+ year old motor
Cool - thanks bud - no, there's no known symptoms or problems - I'm just farting around with it. I just replaced an injector and I had the thing open so I figured i'd fool around with it. It's very strange how I couldn't get the distributor to line up when the screw driver was actually at the crest of the movement. Some cylinders seemed to be way off...there were 2 crests I think in one full rotation of the distributor. I'll try it again maybe next year.
So far the motor seems OK, no problems, except a leaking exhaust manifold - and i'm concerned that even when I replace the gasket with a new one, it's going to be warped....I've been driving around with this ticking/crackling sound for a year or two now...maybe more. Actually, is there anything you can recommend I do once the engine is removed, how I can be certain that manifold won't leak after I put the new gasket in? Would high temp flange sealant stand up to those temps?
![Confused](https://maxima.org/forums/images/smilies/confused.gif)
![Stick Out Tongue](https://maxima.org/forums/images/smilies/tongue.gif)
04-16-2020 05:15 AM
Kyle Lee Cleveland
09-28-2015 09:01 PM
