Easy Mirror Mod
Thats a good question im not sure that grit it was I do know it was green in color with a yellow back and i used a sanding block also and just make sure u cover everthing with tha primer. and do a light coat of black first let dry then go back in with about 2 more coats if u do one thick coat its going to come off and for the other people take mirror off before u paint them i didnt and i messed up the first time had a few dips on it.
For the side that is shown I think i used the "color place" primer but upgraded to the "dupli-color" for the other side. both work fine... Here is tha problem with the blacks..."krylon" flat black and "color place" primer is whats shown in the picture. on the other side i use the "dupli-color" primer and the "color-place" flat black AND IT SUCKS it looks dry!!!DO NOT USE COLOR PLACE... any other questions just ask...
U can use any primer just make sure u USE KRYLON FLAT BLACK because the color place flat black sucks. but with the color place primer get about three good coats of it the Dupli color primer says it fulls in deep scratches & minor imperfections...
it depends on what type of primer you use if you should sand or not....IMO working in a body shop everyday you shoudl always atleast scuff the primer before applying paint just to make sure you have proper adhesion...The best primer of course comes out of a paint gun but if you have to use spray can primer then apply in light coats and scuff only after primer is fully dry right before applying paint...
Sounds good to me...thanks for the correction.
i wish my maxima was white, but its black. smh.. if i had a white maxima ill make it a panda. black roof, black mirrors, black side molding, black door handles, sideskirts, bottom bumpers, and black 17" wheels with a nice drop. pls feel free to use these ideas
Apr 16, 2020 05:15 AM
