Can Someone Comment on How To Replace Fuel Pipes & Hoses to Tank?
Old Sep 8, 2009 | 02:38 PM
1993-VG30E-GXE's Avatar
Not much info in the FSM on this.
-Do I need to lower the gas tank to get access
-Do I need to remove the rear back seat and pull the fuel pump up?
I want to replace those fuel hoses too going from the pipes to the pump.
Old Sep 8, 2009 | 04:17 PM
BenStoked's Avatar
Jesus was a Zombie.
probably have to drop the tank and remove the back seat. you can probably get away with just the bottom, but I recommend pulling the back out, as well.
Old Sep 8, 2009 | 05:49 PM
Made some progress. Cut out the old lines & brake lines, but regarding those hoses - I think there's 2 they go to the pump, would you re-use the original ones? They don't look cracked, and they are accessible from under the car by 2 fuel inj clamps. I'm sure the full way to repair it is to lower the tank but that seems like a major hassle.
How hard is it to lower?
Old Sep 8, 2009 | 08:04 PM
Dayle97SE's Avatar
It is possible to do w/o dropping the tank. I replaced my fuel sending unit/pump thru the rear seat and the hoses by lifting the rear of the car and removing the rear-drivers side wheel.
Old Sep 8, 2009 | 09:20 PM
Thanks bud. I got the pipes out, they were really brittle and flakes were flying into my face. I see now where the hoses feed to, as well there's a short vacuum hose.
Old Sep 9, 2009 | 03:40 AM
nitrous360's Avatar
Did you buy factory lines? I have to tackle this before winter. Not looking forward to it.
Old Sep 9, 2009 | 10:42 AM
This is a pretty horrible job nitrous. Wear safety glasses or the corrosion bits will fly into your face when you start moving the lines. Here's what I suggest:
1. Use penetrant and heat to loosen the little screws that hold the brackets or the heads will snap off as some did on mine so I need to drill them out now
2. Remove the little hex nut holding the rear LH parking brake cable to the side of the radius rod bracket
3. Once you pull the lines out of the brackets, the brackets may be shot and need to be replaced - i'm going to do makeshift probably.
4. Snip all the lines out with heavy duty shears or wire cutters and catch the gas and brake fluid in a drain pan
5. Remove front stabilizer bar
6. Remove front LH transverse link
7. Remove front LH transverse link gusset
Checked the price on the OEM lines, way too expensive. A roll of 25 Foot of brake line is like 15 bucks, so i'm doing it with a tube bender.
JRod28
Dec 29, 2023 09:56 PM
rbuswell
Nov 17, 2016 04:54 AM
stromm
Aug 27, 2015 04:13 PM
305head
Aug 26, 2015 09:03 PM
homewrecker
Aug 24, 2015 08:56 PM
