how much would she be worth?
i have a 1990 maxy that thanks to my dads ghetto riggs he sent the engine to hell. but anyways i took out the engine trying to fix it but he just made me lose hope when he made it worse. long story short how much would it be worth for a rolling shell? or with the engine and sell it as a "needs new engine" type thing
it has about 300k on the chassis but it has no rust, 5th gen se wheels, good paint for a old car brand new rack and pinion, very clean interior *i hate dirty cars*
the last pic is before i untinted it andput the se wheels. *its a tan dash cover*
i was thinking about that cause i do love the car and it hurts to get rid of it. so im thinking of telling my old man that we should just wait and get a jdm spec
So, again, what's your reasoning for selling it? If you sold it you'd get $500 or so.
And what kind of car do you expect to get for that $500? Probably something like you've already got that needs work. Selling your car just puts you in the same boat you're already in..
I mean, you can get a perfectly good VG engine for $200 if you look around a bit.
OR you could get a usdm spec, which is practically the same thing, and save yourself a grand. ( I presume you are talking about an engine)
The cars body looks immaculate!! I would just get a low mileage engine from a junk yard or something, or look around. You can probaly get one pretty reasonable too now days, and since you already know how to work on the car and are familliar with its parts, I would keep it. If you sell it someone else will have it and do the same thing with it. And like someone said before, if you replace the engine, and then want to sell the car, you could ask for about $1500 to 2000 or so and buy you another car if thats what you want instead of selling it for a little of nothing.
i was, and i could just drive to los angeles and get one for 600.
i just going to get a low miles one like you guys say and drop it in. i did get a 89k one as the second engine *original was screwed* and the 89k lasted me to only 110. hopefully the other engine goes as planed and lasts me atleast 200k
my dad messed up the heads by trying to get out some broken studs and he over drilled and made the holes wayyy to big and they leaked water too
Just put another junkyard engine in it. let a pro work the exhaust studs over while it's out of the car if you need to..
also install a new water pump, timing belt, and crank/cam seals while you have it out of the car. once that's done, the engine should last another 60k miles with zero maintenance.
That's what I just did.... motor with one year warranty cost $600...
i ment as turbo over time and just put in new heads. i would not want to screw up a new motor. im going to the jy later and getting me heads and doing a gasket and pump replacement like you guys said so ill make it last
Forge277
Jun 13, 2016 09:26 PM
Dasmith
Sep 23, 2015 08:28 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
