trunk lockset removal-1993 gxe
Old Nov 30, 2001 | 03:07 PM
abbey's Avatar
How does one remove the trunk lockset from a 1993 gxe after the rod is disconnected and the 2 hex screws are removed?
My lockset is frozen and needs to be replaced.
Also, looking to replace the stock wheels without making any modifications. Present size is: 15 inch Any suggestions?
Thanks!!
Old Nov 30, 2001 | 03:41 PM
All123Pro's Avatar
Re: trunk lockset removal-1993 gxe
Thanks!!
You need to remove the bolts? that hold the center-piece of your rear lights, once you do that your center-piece will pop off. As far as new wheels try www.tirerack.com they usually have good deals.
Old Nov 30, 2001 | 11:01 PM
Matt93SE's Avatar
STFU n00b!
spray inside your lock with WD-40 and wait 10-15 minutes.... then spray again....
then just play with it- stick the key in and try to turn it back and forth, spent a few minutes just inserting the key and trying the lock. after 5-10 minutes of this, I've broken loose FOUR frozen trunk locks on 3rd gens. mine hasn't frozen up since either.
REDinLV
Aug 15, 2024 12:30 AM
tarun900
19
Dec 20, 2021 06:57 PM
Socalstillen
Sep 20, 2015 11:46 PM
Mikes14Max
Advance Paint and Body Work
Sep 14, 2015 05:28 PM
