need help installing a cd player
Old Nov 26, 2001 | 04:10 PM
maximan's Avatar
can someone point me to instructions on how to install a cd player to a non-bose system. I did a search and really did not find much. Thanks
Old Nov 26, 2001 | 04:20 PM
All123Pro's Avatar
Re: need help installing a cd player
Check out Craig B's site
http://www.prism.gatech.edu/~gte671n/mymax.html
Old Nov 28, 2001 | 03:57 PM
maximan's Avatar
Thanks platinumplus. that's very informative. The only I'm not sure of is in what case I need to by pass the amp in the rear speakers. and how do I do it. anyone? thanks for your help
Old Nov 28, 2001 | 04:49 PM
N34JZ's Avatar
Needs non-Maxima Friends
you
Shouldnt have to if you have a non bose system. I dont think you have amps on the rear speakers.
Old Nov 28, 2001 | 05:15 PM
ghostmax's Avatar
maximan,
is there 1 amp for both rear speakers? if so, then there should be a harness leading into the amp (maybe 2). if you're bypassing, then you want to splice into the harness before it goes into the amp and take the speaker wires (2 thin ones) and connect those to your speakers. the bose system has 4 wires: 2 thin, 2 thick. just make sure you use the thin wires. the black is negative and white (?) is positive.
take this information with a grain of salt since i've only by-passed the amps on my bose. if you can't connect the rears, then you might be better off running new speaker wires for the rears (and maybe even the fronts).
good luck.
Old Nov 28, 2001 | 06:35 PM
N34JZ's Avatar
I could have sworn
Originally posted by ghostmax
maximan,
good luck.
he said he had a non-bose system. oh wait
guess im not losing my mind
Old Nov 28, 2001 | 07:42 PM
Gamezilla's Avatar
I just put in a new CD player and speakers in active speaker system
take two wires running to each speaker. Take wire cutters. Cut wire. Crimp wire to new speaker wires. Done.
There is a singel amp in the trunk, but I don't think it really does much. I'm pretty sure I've blown it out, but I sure as hell can't tell. Active speaker system is REAL easy to work with. When puttin the CD deck in, though, make sure you have the dual diversity antenna adapter.
Old Nov 28, 2001 | 09:30 PM
djslinkyz's Avatar
Re: I just put in a new CD player and speakers in active speaker system
if you've blown it, your rear speakers won't work. pretty damn easy to tell.
Old Nov 28, 2001 | 10:25 PM
ghostmax's Avatar
Re: I could have sworn
Originally posted by N34JZ
he said he had a non-bose system. oh wait guess im not losing my mind
I never said he didn't have a non-bose system. i was merely passing on advice for by-passing the amp, which would probably be similar to a bose system. thanks, please drive to the second window.
Old Nov 29, 2001 | 11:16 AM
N34JZ's Avatar
Re: Re: I could have sworn
I dont think the non bose systems have amps for each speaker but mabey they do. so dont get so defensive.
Old Nov 29, 2001 | 06:15 PM
maximan's Avatar
thank you all for your comments. the circuit city guy led me to believe that I have to bypass the amp(s) in the rear. Yes, my max has Clarion HU & active speakers. We'll find out when I start working on it this weekend. I'll post back so you all know the result.
Gamezilla! yes, I do have the antenna adapter & wire harness.
Old Nov 30, 2001 | 06:31 PM
maximan's Avatar
OK, there's an amp in the rear on the left side. Without rewiring there's no sound coming out from the rear speakers.
Old Nov 30, 2001 | 08:24 PM
Gamezilla's Avatar
Sounds like you blew your amp. That's gonna cost a lot of $$$, but I'm not sure how much (mine's still working, so I haven't replaced it). I don't know how to install them, so I'd have an audio place do it if I were you (looks kinda complicated, but it may look worse than it really is). Before you go out and get an amp, check to make sure you put the speakers in right. You should have:
Unplugged the plug from each speaker. Taken the wire that ran into the stock speakers and moved up and inch or so and cut the wire (keeping the plug just in case). Taken the new speakers and plugged the + and - end into the speaker. Taken the other ends and crimped them to the cut wire from the car, matching up stripes with stripes and solids with solids. If you've done it right, and your sure there is an electrical flow, then you've blown your amp for sure. Go to courtesy nissan for that part.
To test the current, wet your finger, then grab at the exposed metal the + and - wires connecting to the speakers. If you recieve a shock and forget what speakes are, then you don't have to worry about it anymore! j/k
Old Nov 30, 2001 | 08:32 PM
djslinkyz's Avatar
the stock amp is ****. its better if it wasn't there at all.
Old Dec 1, 2001 | 06:42 AM
ghostmax's Avatar
Just bypass the amp as I described in a post above, and you should be fine. Look for a harness leading to the amp. You want to cut into that and splice only the speaker wires to the speakers, thereby bypassing the amp. Right now, your HU is sending the signal to your rear amp (which is dead), and the dead amp is sending the signal to your speakers. That's why passing the amp works--because the dead amp never sees the signal in the first place.
MaxLife17
Jun 27, 2019 01:37 PM
Excalibur23
Oct 13, 2015 04:33 PM
Max8
Sep 22, 2015 02:53 PM
2kmaximel
Sep 16, 2015 03:19 PM
Johnny9595
Sep 3, 2015 05:18 AM
