Transmission Seals
Old Nov 4, 2009 | 08:26 PM
1990maxGXE's Avatar
Transmission Seals
I am about to replace the transmission on my max and was wondering what seals I need to buy and what transmission fluid to buy and where to get. It looks like I can get the seals from O'reilly autoparts. Also im guessing i should probably replace the filter on the transmission since it is used with 59,000 miles, How hard is this to do and do you guys recomend a transmission cooler for it and how much do those cost?
Im sure some people will read this and think im an idiot but I want to make sure i have all the parts since i am in college and am trying to go home and get the transmission installed over the weekend.
Old Nov 4, 2009 | 09:38 PM
CMax03's Avatar
You might be able to get the driveshaft garlock seals at O'rielly....maybe the input shaft seal (torque converter) but I doubt it! Go to courtesyparts.com and get all 4 items...1.the drivers side garlock seal 2.passenger side garlock seal, 3.the torque converter input seal 4.input shaft Oring.....
Old Nov 5, 2009 | 02:47 AM
richkcmo's Avatar
pls keep us posted on this. thanks.
Old Nov 5, 2009 | 09:56 AM
DanNY's Avatar
Ad·min·is·tra·tor
axle seals
top pan seal (if it looks iffy)
torque converter seal
engine rear main seal
no serviceable filter on the RE4F02A.
maybe get a can of flush to flush out the radiator cooler or just get an external one (cold climates should get a t-stat on the cooler). cooler runs about 20-50 bucks. get a bar and plate and avoid the tube and fin models.
personal fav fluid is Amsoil universal ATF or Redline ATF. If you must mobil 1 will work in a pinch but i'm not a huge fan of their ATF.
good luck.
Old Nov 18, 2009 | 01:36 PM
1990maxGXE's Avatar
Ok I may be an idiot but I have searched courtesy parts and am not sure about the right seals to order i think i found the torque convertor input seal but i am not sure also when i search the other seals i cannot find any with the same names
is this the torque convertor input seal or is it something else
http://www.courtesyparts.com/30401j-...ml?cPath=1610&
And if someone knows what the part #'s are that would be helpful since I have never done a job like this before and do not have the transmission and car to look at as a reference since i am in college and my car is at my house
Old Nov 18, 2009 | 08:07 PM
jbbons25's Avatar
On courtesyparts, go to section 312 under Power Train
Axle seals - 38324P and 38324Q
Top pan seal - 31396
Torque Converter Seal - 31344M'
For the rear main seal, go to section 110 under Engine Mechanical and it's number 12279
user 11122324
42
Jul 18, 2022 03:35 PM
mpbclutch33
Dec 26, 2015 11:11 AM
Pied
Sep 26, 2015 03:29 PM
