Side door moulding solution?
Old Dec 2, 2001 | 05:37 PM
Mad Dhan's Avatar
My dads 91 max's side door moudling have gone or faded. Would the only way to restore them is a repaint? Ive seen this on other 3rd gens and i know its proablay been asked here and i apologize. I looks in the search but could not find anything. Any help? thanks in advacne
Old Dec 2, 2001 | 07:09 PM
matt92gxe's Avatar
well... i removed mine and the car looks great without them. the only thing is, is that it takes hours to scrub off the adhesive that holds them on. they just peeled right off and then scrub away at the glue!
another thing you could try is to put armor all on them. i know it sounds crazy, but it works. those moldings are plastic and the armor all will shine them right up.
good luck!!
Old Dec 2, 2001 | 09:41 PM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
option 1....to restore them...that would require the removal of them, sanding, repainting and reinstalling them....
option 2....completely remove them...
Old Dec 3, 2001 | 10:02 AM
matt92gxe's Avatar
i'm telling you to try the armor-all before you do anything. i bet it makes it look better. the only thing is, you will have to start using it every couple of weeks to keep it shining.
Old Dec 3, 2001 | 03:20 PM
Mike92GXE's Avatar
Do you have any pics of your car with without the door moldings?
Old Dec 3, 2001 | 04:34 PM
ChrisCheezer's Avatar
I JUST TOOK MINE OFF :)
good luck!!
HEy!dude take them off.. it looks so much better.. i used an ice scraper and goof-off (2 cans) after i peeled the guards off i let the goof-off soke in then just scraped away each layer of adhesive till it was all gone. it took me an hour each side. The ice scraper did not scrach the paint at all but i did dull it to nothing.
Old Dec 3, 2001 | 04:36 PM
good luck!!
HEy!dude take them off.. it looks so much better.. i used an ice scraper and goof-off (2 cans) after i peeled the guards off i let the goof-off soke in then just scraped away each layer of adhesive till it was all gone. it took me an hour each side. The ice scraper did not scrach the paint at all but i did dull the scraper to nothing. lol
Old Dec 3, 2001 | 09:34 PM
Mad Dhan's Avatar
I dont think it is really a feasable solution. Upon further inspection, It seems like it is rust that has formed and that would be unremovelabe, right? Thanks for the suggestion anyway, srry i never gave all the info
Old Dec 4, 2001 | 07:46 AM
matt92gxe's Avatar
then you should probably just remove them. the car looks good w/out them, but be prepared to spend some time on it. it will take a lot of scrubbing to get the adhesive off.
good luck!!!
Old Dec 4, 2001 | 08:00 AM
Strrrive's Avatar
Re: Side door moulding solution?
I actually covered mine over with a carbon fiber tape I got at this place on Queens Blvd NY. It lasted for about 4 years until it started to rust (don't ask). It was a real subtle look but when people noticed it they flipped.
Old Dec 4, 2001 | 08:54 AM
Chris91SE's Avatar
Eagles Fan 4 Lyfe
pics on my site
http://maxima.cardomain.com/id/chris91se
Old Dec 4, 2001 | 09:08 AM
roadiusmaximus's Avatar
Mad Dahn,
Before i had my entire car painted, i had the tops portion of all my moldings have sun damage on them. Removing them and reinstalling them would be difficult in the sense that you need some really good adheasive to keep it on there. What i did initially, was to tape up (masking tape) the surrounding body of the car (which will cover up really well if you line the tape just between the crease of the molding with the car), sand, prime it, and paint it. If you take a little time, sand it evenly, prime and paint it correctly (back and forth and very lightly, not holding it over the thing) it will come out very nicely. On my maxima it matched to car perfectly. All if you find the correct match of paint, they dont seem to be making to the charcoal grey colour anymore. But thats just me.
Good luch
IM xpandermedway
Old Dec 19, 2001 | 05:44 PM
davis4004's Avatar
Take those things off! It makes them look so much better. Use a hairddryer some simple green and lots of paper towels.
matts95max
Apr 23, 2025 10:44 AM
The Wizard
24
Oct 1, 2015 08:47 PM
maximusrising
Sep 4, 2015 06:31 PM
FanaticMadMax
Sep 4, 2015 02:45 PM
