Well, I REALLY did it this time...
Old Apr 10, 2010 | 11:44 AM
  #121
maxitech's Avatar
Originally Posted by jbbons25
I think you're talking about the water heater control valve. If you are then:
Yes, thank you!
Old Apr 10, 2010 | 04:51 PM
  #122
maxitech's Avatar
Anyone got a tip on getting old gasket material that is REALLY on there off?
Old Apr 10, 2010 | 05:02 PM
  #123
CMax03's Avatar
Originally Posted by maxitech
I sure hope it does! I need to check to see if that hose will be in tomorrow. If it isn't, I suppose I can ghetto-rig the old one with electrical tape until the new one arrives on Monday. I just want to start it and see if runs...Maybe even take it for a drive. It's just the hose that goes from the IACV to the intake pipe right before it meets the upper intake manifold.
Hectic, please do let me know what brand that bearing is. I need to start shopping around for a tranny shop. The one place I had quote me said $500 parts and labor. Not too bad, but I would like to check with some other places first before pulling the trigger.
That's what I did on mine as well, and it's still working fine,,,
Old Apr 10, 2010 | 05:10 PM
  #124
Greeny's Avatar
¯\(°_o)/¯
I use a soft bristle wire wheel with cordless drill..
Old Apr 10, 2010 | 07:23 PM
  #125
CapedCadaver's Avatar
Call me Wookiee Goldberg
yep.. too stiff and it might gouge the metal. i had to resort to this method when doing my brother's oil pump gasket.. but i got lucky i guess, cuz it didn't leak after i put it back together.
Old Apr 11, 2010 | 02:54 AM
  #126
CMax03's Avatar
Apply some toulene to it then scrap it right off, cordleess/or electric drill and a wirewheel brush to really clean up the stubborn parts....
Old Apr 11, 2010 | 09:52 PM
  #127
maxitech's Avatar
Not quite done yet, getting close...Sometime this week.
Old Apr 14, 2010 | 06:40 AM
  #128
maxitech's Avatar
Thought I would be able to start it yesterday, alternator grounding bolt broke off while tightening it, but I was able to extract the screw and find a new bolt after removing the alternator. Too busy to work on it today, but tomorrow I hope to start it once the alternator is reinstalled.
Old Apr 14, 2010 | 12:12 PM
  #129
maxitech's Avatar
Quick question: There is a vacuum line coming off the corner of the intake manifold closest to the passenger side and the firewall. There is a check valve in the line. Which way is it supposed to go? Should it block air trying to flow into the intake plenum or away from it?
I would think the correct answer is away, but I want to be sure.
Old Apr 14, 2010 | 01:37 PM
  #130
Matt93SE's Avatar
STFU n00b!
you want engine to suck air in, not go out. orient check valve so it does that.
Old Apr 15, 2010 | 04:45 AM
  #131
maxitech's Avatar
That's what I thought...thanks
Old Apr 17, 2010 | 04:57 PM
  #132
maxitech's Avatar
IT'S ALIVE!!! As of a few hours ago it is out of the garage it was sitting in and back home...Now I'm off to the car was to get rid of 3 1/2 months worth of dirt and dust!
Old Apr 18, 2010 | 12:11 AM
  #133
maximo018's Avatar
You could let the rain take care of that later today.
Old Apr 28, 2010 | 08:32 AM
  #134
maxitech's Avatar
Update on how it's runnin':
All things considered, it is doing pretty well...Three small issues tho:
1) It has a miss ONLY at idle. It runs great when I step on it. I replaced the spark plugs, added 1/3 bottle of BG44K to 1/3 tank of gas and ran it out, then filled it up and added a full bottle. We will see if the miss goes away after I run this tank of gas through it.
2) Small coolant leak where a metal connection w/ 2 bolts mates up below the intake manifold. I put some red RTV on it when I put it back together, but that isn't stopping it from leaking. Maybe I tightened the bolts down too much. Looks like I will have to pull the manifold to get to it and reseal it...D'oh!
3) I have a noise coming from one of the belts. I need to poke around and figure out exactly where it is coming from. It is either the P/S pump idler pulley being worn out or the timing belt being too loose. That would suck, since I followed the factory procedure to a "T" when putting it back together. Oh well, what's a few more hours of labor?
Old Apr 28, 2010 | 10:56 AM
  #135
Darkwing48's Avatar
Congrats
Old May 3, 2010 | 08:34 AM
  #136
maxitech's Avatar
The car is running better now that some of the BG44K has been through the fuel system and I found my coolant leak is not where I originally thought it was. Rather, it was a clamp that I had forgotten to tighten, so now she is running like a champ! Great timing, since my Corvette has started to run rich and will be going to the shop for a few days...
Old May 4, 2010 | 10:52 AM
  #137
CMax03's Avatar
I'm happy for you...Obi Wan!
JoeyG007
Aug 17, 2002 07:59 AM
kafene
Aug 6, 2002 08:18 PM
jkotel
Aug 1, 2002 11:34 AM
hlh0501
27
Jul 30, 2002 01:00 PM
