Brake options that will fit under a 16" wheel?
Old Jan 6, 2010 | 06:05 AM
cardana24's Avatar
Blown
I have the wheels tha I want and they are 16s. I know most of the common BBKs require a 17 or bigger. Do I have any options with 16" wheels? I already have Z31 rotors in the rear, I also have SS lines that I am going to install. Should I just get some Hawk HPS pads and call it a day or are there options? I have 2 sets of J30 calipers that I can use if they would really offer any improvement. Let me know what you guys know or think. Thanks for any help.
Old Jan 6, 2010 | 06:09 AM
CapedCadaver's Avatar
Call me Wookiee Goldberg
the 5.5gen brake kit i made should fit under 16's since the 5.5gen GXE had 16's. if you are not in a massive hurry my 5.5gen kit is going to be for sale (as the car is being parted out) in feb or march. As many problems as my 3g had, the one thing it did well till the very end was stop.
Old Jan 6, 2010 | 06:24 AM
Niccos89's Avatar
How common are Z32s over in the USA?
Their calipers and rotors off the turbo models are the same as R32 GTR / R33 GTST which is what I did on my Ceffy, and it's the best brake upgrade I ever did. 4 pot fronts and 2 pot rears makes a massive difference.
Not sure how the 300zx / Skyline brake cylinders compare to the J30 cylinders though...you might get a spongy feel in the pedal.
Old Jan 6, 2010 | 06:46 AM
cardana24's Avatar
Blown
Does that stop much better than stock? How much work was required to make the 5.5 gen stuff fit?
Z32 stuff is not rare, but I know it takes modifications to make it fit.
Has anyone done this on their third gen? I know Z32 calipers and cobra rotors is a popular set up but I cannot fit that big of rotor under my wheels. With out adding the larger rotor is there a point of me switching my calipers?
Old Jan 6, 2010 | 06:52 AM
Niccos89's Avatar
What modifications? I test fitted a caliper to my Maxima knuckle the other day, went on with no drama's.
The Z32 rotors will fit under 16"
Old Jan 6, 2010 | 07:11 AM
remove all your stock brake crap
bore the holes on the hub out to 14mm or 9/16"
install 5.5gen stuff just like you would normally
if you want to buy my hubs with the brakes already on them you can, i just need a little more time cuz i'm about to go on a business trip for a few weeks.
i wouldn't call it a "track kit" improvement (compared to say, the z32 brakes with 6g or cobra rotors) but it is a perfect compliment to the z31 rear brake upgrade (which you already have, right?) and my car stopped a heck of a lot better than it did before i started my brake upgrades. I noticed the improvement from the front brakes more than i did from the rears once the pads broke in (i got used pads but new rotors.. took a while for them to match up).
Old Jan 6, 2010 | 07:27 AM
cardana24's Avatar
Blown
I am not exactly sure but I thought something needed to be grinded/milled down...I am probably thinking of the cobra rotor set up.
Are the 5.5 gen rotors bigger? Are the calipers still single piston?
I have access to a set of Z32 front rotors for free and I already have J30 calipers. Has anyone tried this set ups? Z32 front rotors and J30 calipers? Just curious since I would only need to buy pads to make this one happen.
Old Jan 6, 2010 | 07:38 AM
single piston but larger rotor. 11.65" vs 11.05" stockers. basically you get more leverage against the rotor when the rotor is larger. that's why people that roll on 24's with stock brakes are idiots cuz the wheels have to much leverage over the brakes.
Old Jan 6, 2010 | 07:49 AM
Niccos89's Avatar
Z32 rotors with J30 calipers wont work I don't think
Other way around will...the Z32 caliper can accomidate its own (Z32) rotor, or J30 rotor (in this case, its obviously only going to chew through half the brake pad, not the whole thing).
Z32 rotors are 296mm + 297mm ... not sure on thickness, do a Google Search...these are bigger than J30 I believe.
Old Jan 6, 2010 | 10:20 AM
BenStoked's Avatar
Jesus was a Zombie.
ima kick you ***. didn't I say I want it? teh whole she-bang, front and rear.
Old Jan 6, 2010 | 10:28 AM
you did?
oic
Old Jan 6, 2010 | 10:39 AM
BenStoked's Avatar
Jesus was a Zombie.
^^lol @ teh
Old Jan 6, 2010 | 10:46 AM
^^lol @ teh
i'm sorry i can't hear you over all 18,900 posts i have
now ben, i assume you have good caliper clearance on your current wheels? which are 16's right? cuz the caliper clearance on the 5.5's is probably the same but of course having some breathing room is always good.
Old Jan 6, 2010 | 10:54 AM
BenStoked's Avatar
Jesus was a Zombie.
well, when I swap out my transmission for that VE-5 you're gonna sell me... (right?), ill have some 17"s by then. Right now, I am rockin' some sawblades (broke one of the mags, hitting a pot hole fortunately, they were crappy pep-boys or something wheels from ten years ago)
edit: mebe we should get you to start a "caped's other pre-partout thread; post your claims here" thread in teh clasifieds
at us for spamming cardana's thread...
Sorry, man...
Old Jan 6, 2010 | 11:19 AM
maxitech's Avatar
I went with the Q45 setup awhile back and have been very happy with it. 1st Gen Q45 (or J30) 2-piston calipers will bolt right up. All you have to do is get some matching rotors and have 4-6 (IIRC) mm machined off the OD. The rotors are twice as thick as stock, so there is much more material available for heat dissipation. You will also have to get rid of the dust shields.
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
twotonezed
Aug 16, 2015 11:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
