gas smell
Old Jan 13, 2010 | 01:13 AM
shortymust23's Avatar
gas smell
I'm starting to smell gas in the front of my car when i open my hood i smell it , and when i turn on the heat .i changed my flex pipe about 6-8 thous. miles ago what do you guys think it is thanks.
Old Jan 13, 2010 | 07:05 AM
ve30max's Avatar
Check your fuel lines, they are easy to see, and you shouldn't have any trouble if you have a manual for this car. The injectors are visible as well and you can typically see fuel leaking from them, if there is any escaping. The fuel lines come up from the bottom of the car, are routed on the drivers side underneath the brake booster/master cylinder, and connect to the injector rail assembly via. rubber hoses. The hoses run parellel except for a small portion which connects to the fuel filter, which is on the firewall, and it looks like a small can with a hose connected to ports on the top and bottom. There is a fuel evaporative canister which filters the fumes so that the tank isn't pressurized, the filtration makes the vapors safe for the engine to consume, I am making an assumption with the "safety" aspect, but I seriously doubt this is the source of your smell. The fuel system is pretty isolated, in my opinion, and if you can't find the leak, you're not looking hard enough. Good luck!
Old Jan 13, 2010 | 07:14 AM
DanNY's Avatar
Ad·min·is·tra·tor
please do a search for this issue.
Old Jan 17, 2010 | 10:34 PM
gapboi210's Avatar
I did mine and the smell showed up again next year. Saw the hoises were wet again. I made sure i got a high quality FUEL INJECTION hose and used fuel injection clamps. Haven't had anymore issues.
Old Jan 17, 2010 | 10:44 PM
CMax03's Avatar
+1^^^^
Old Jan 17, 2010 | 11:41 PM
maxinout93's Avatar
when its cold outside is mostly when u probaly notice the smell. It most likely is coming from one of the fuel injector hoses. Get some new hoses. FUEL INJECTOR HOSES. Mine is still leaking sometimes, and I though I tighted up the hoses when I replaced my valve cover gasket.
mclasser
22
Nov 12, 2020 01:58 PM
maxinout93
Oct 31, 2015 02:04 AM
ef9
Oct 4, 2015 08:43 AM
