What parts fit?
What parts fit?
SO... Im aware that we dont have many aftermarket parts and the only things that ive seen that you can take from another car of the same or different make and model are the e36 headlights... I need new shocks but dont wanna get new stock shocks and struts...
I have g35 wheels and tires 225/45 18 in the front and 245/45 18 rear and they rub like crazy in the back the tire is coming apart slowly but surely... I need to fix this problem asap...!
there is no "shocks and struts"... just struts. and nothing from any other car will work in that department, you have to use stuff made for the 3rd gen or just deal with your tire rub and crappy ride
Taking my Maxima to the Max!
The correct tire size should be 235/40/18. That should fix your rubbing problem if your wheels are the right size/offset. G35 wheels should fit, but if they are staggered size and wider ones are in the back you have too role your fenders and/or move the wider ones up-front or just get the thinner ones for the back as well. We would need to know more info about your wheels and if you are lowered to help you with the rubbing issue.
Konis are the best strut replacements for our cars. Tokicos are next and KYB GR-2s are the least. Good Luck.
I thought not but anyways... I wasnt talking about that department I was talking about just parts in general Cape... But the ride is crappy x10 and i wanna get some new ones ASAP but dont have the money to kick out due to my newborn, feel me? Ive seen where you talked about the Tokico Struts but hell they are up there price wise also when i replace them should i replace the springs too?
also the wheels do turn heads guys... and the right is pretty smooth when i dont hit any bump... but i wouldnt go bigger then 18s ive seen some with 20 and 22 that look pretty stupid lol dont know why they would use wheels that really dont fit but yeah thanks for the help guys...
I see stillen has these what do you think about them http://www.stillen.com/product.asp?i...U&b=Suspension Techniques&year=1992&make=NISSAN&model=MAXIMA
yeah, but then you loose turning radius.
yea a 40 profile would have been more appropriate for a 245mm tire on an 18" rim, only 0.2" taller than stock. 45 profile for that width and rim diameter makes the tire 1.2" taller than stock
yeah i know the feeling. my ex roomie ran z33 wheels with oem z33 tires on his z31... which were 1.1" (or 4.2%) too big in the rear. then he got a flat and had to buy another of the wrong-size tire rather than 2 (well, really 4 since the fronts were a full profile too tall as well) of the right size. but i'm sure it made his car quite a bit slower to accelerate from the effectively taller gearing of the tall tire. i'm going to use stock-size tires on mine, plus mine's just a 2 seater so it's lighter
if we're on the topic of wheels, here comes the noobage ive only run on stocks before so bear with me, i know nothing lol
bought these Momo rims, guy brought a JDM Z32 over and wrecked it, rims came with the car from Japan and he wanted them gone, got them for $180. fronts have Falken 245's on them, rears have 295's IIRC. i think theyre 17's, havent looked at the width. think theres any chance of them fitting a 3rd gen on the rears? i can give whatever info needed. dont know the offset but its not MaD TyTe offset
someone said they could possibly fit and you can get them narrowed, i cant see them fitting. the plan was to just keep them until i can sell them to someone with a Skyline or whatever that can fit them or if i get one anytime soon just use them then
This max has been improved on by 505max94se.
um... spacers have nothing to do with tire width, the only time spacers matter is when you're dealing with offset. your wheels just happened to have too high of an offset to fit without spacers. for other people with lower offset wheels, spacers won't be necessary even with the exact same 235/40/18 tire that your particular setup needed spacers for. like my 17x7+22 chrysler wheels with 225/50/17 tires, they stuck out TOO far because they didn't have enough offset. with the 5.5gen wheels, they didn't need spacers either. and i transferred the exact same tires off one set of wheels and onto the others.
what do you mean narrowed? a 295mm tire is a 295mm tire... if you buy a narrower tire, it's NOT a 295, it's something narrower. you might be able to run that wheel that the guy had 295's on with a narrower tire but most likely it would involve a very sizeable stretch and you'd end up looking like one of those hellaflush *******.
guy guys guys ive already made a thread about the G35 wheels and tires... this thread was to find out what part from other make and model cars will fit the third gen... and to find out if i would have to use aftermarket struts for the third gen or stock and if there is any other GEN maxima parts that i could use... some of what was said did help but i dont want the big tires in the front my struts are done for... it would be pointless... so its really not about tires i already know what tires im going to get. but thanks
my wheels are 18x8 225/45 front and 245/45 rear
the 225/45 fits perfect front and rear (no rub)
the 245/45 rubbed the strut in the rear pass. side and started on the driveside yesterday. They bout also had i think 8mm or 9mm wheel spacers on them so they dont rud the strut...
So im gonna go 225/45 all around... I just need to know what's the best bang for the buck is... just had a newborn so im not tryin to go all the way out...also you guys skipped over what i asked about the stillen product..."I see stillen has these what do you think about them http://www.stillen.com/product.asp?i...U&b=Suspension Techniques&year=1992&make=NISSAN&model=MAXIMA"
but are you talking specifically about the g35 wheels needing the spacers? cuz the cobra 8" wide wheels would not need them, since they have a little less offset and therefore sit further out naturally.
well first of all 245/45/18 is the wrong size for the car.. should be 245/40/18. taller tire means more rubbing alot of the time.
I know I guess I did not spell out my whole point. Since I am using a wider wheel (.5" wider than Jeff's) then I would need a higher offset to bring the wheels in a little more so they will not hit the fenders. All of this is just a compairson to jeffs fitment. Sorry, I thought it was clear what I saying.
Sup man... Yeah 245/45/18 suck... but I bought the wheels along with the tires for $350 couldnt beat that... the rear 245/45s were the tires that came on them... I havent bought new tires yet and the 245/45s are the reason i used the spacers along with me needing new struts...i got the spacers because the wheel would just have been rubbing on the strut so the spacers gave it a bit more clearence so now the wheel sit pretty flush with the body... but the finder is just eating away at the tire its i have more than just me in my car or if i hit a good bump...
umnitza
09-01-2015 01:03 PM
kirkhilles
08-08-2015 10:53 AM
