Door trim/Mirror removal
At a local junkyard there is a Maxima in the same color as mine, although it must be an earlier year as the taillight is all red, where my 94 is red on top with a stripe of white on the bottom - anyway....
The door trim/door bumper guard/whatever that strip is called is something i need - anyone know how it comes off?
Also, I need (want) a drivers side mirror housing, any help there appreciated as well.
Considering fenders and a door panel, not sure about those yet.....
Maybe that all red tailight!
TIA
TIA
sounds like the rubber along the door is what you want. a heat gun (oversized hair dryer) will make easiest work of it, I believe.
mirror is cake; pull the door panel, pop out the plastic triangle by the mirror, disconnect the harness, unbolt. voila. (recommend finding heated mirrors. they have an extra connector, and need the heated mirror switch from the dash. like I have said before, I use them all the time)
Mirror does sound easy too, thank you again!!!!
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
