Stero install...Just a LITTLE help..
Old Dec 11, 2001 | 10:06 AM
wood94gxe's Avatar
hey,
I got got a new cd player to replace my stock "active speaker" setup. My problem is that i have no clue what the color code is of the wires inside my car...does anyone have a list of what these are, I have searched the forums for a hellufa long time I still could not find it.
thanks!
woody
Old Dec 11, 2001 | 10:19 AM
«§»Craig B«§»'s Avatar
Re: Stero install...Just a LITTLE help..
Originally posted by wood94gxe
hey,
thanks!
woody
Matt93SE's FAQ page has some info here:
http://www.ee.utulsa.edu/~mblehm/faq...fo/radio_info/
that should give you all the wire colors you need
if you need any help with removing head unit or speakers, check out my page:
http://www.prism.gatech.edu/~gte671n/mymax.html
good luck
Old Dec 11, 2001 | 12:33 PM
wood94gxe's Avatar
thanks...but....
hey, thanks man, but that page doesn't have what all the wires are..like the power anntena switch...dimmer switch...stuff like that? do you just match up the colors that come off the adaptor thats on your deck? are the colors like universal for the most part or something? please help me out!
thanks
Woody
Old Dec 11, 2001 | 01:06 PM
Re: thanks...but....
thanks
Woody
easiest way is to buy one of those harness adapters at Best Buy or wherever for about $15 or so
connect all the wires coming from your new radio to the harness and plug it in
the harness will tell you which wires control what and then look in teh manual for your headunit to tell you which wires are which
then connect the ones that are the same
it's pretty easy
Old Dec 11, 2001 | 01:56 PM
Matt93SE's Avatar
STFU n00b!
since yours is the non-bose system, you'll also have to bypass the small amplifier on your rear deck.
instructions are on my FAQ page for this also.
http://www.ee.utulsa.edu/~mblehm/faq...amp_bypass.txt
Old Dec 11, 2001 | 05:40 PM
Dave S's Avatar
thanks
Woody
Check out scosche.com and installdr.com
Pnjboyzz
Sep 4, 2015 09:04 AM
kevin82277
Feb 6, 2002 05:19 AM
adamis
Dec 13, 2001 04:37 AM
gitsum
Oct 16, 2000 06:26 PM
