whats the best engine & fuel treatment?
Doesn't ring any bells for me. I always use the big bottle of Lucas Fuel Additive. Really noticed a difference in mpg after using for several tanks. Gained about 3 more miles per gallon when using and when stopped, maintained a 2 mpg gain (so lost 1 mpg when not in use). I think my '03 runs great, so I didn't notice anything significant in terms of horsepower on my butt dyno. Car did feel more responsive, but my injectors may have been dirty and Lucas cleaned them out.
http://prostores2.carrierzone.com/se...om/Detail?no=3
and is this lucas your talking about the injector cleaner? (if it is, im already using that and it feels smoother, i have 2 bad injectors i need to fix
im not a fan of additives, but after i got my engine rebuilt a family friend told me to try injector cleaner so i threw in a bottle. i dont know why but i was getting horrible MPG after, as in using 1/4 of a tank within a day or two. after i refilled and the injector cleaner burnt off, ive gotten better MPG. i thought i was burning through gas so quick because i was gunning it more after the rebuild but im still gunning it now and getting normal MPG
ehh so i guess my best bet would be an engine flush. i just want to get rid of any sludge if i have any, just in case u know. im a maintenance freak so i keep on top of things. i havnt had time to put in my damn injectors tho.
engine flushes are worth it if you think you have sludge, i just got mine done at a oil change place for $20 with a natural flusher made of soybean and stuff when i had sludge a couple years ago
it was $20, long story short is my 3rd gen is my first car and i was a idiot when i first got it and rode out standard oil to 5000km and got bad sludge, so after the flush i got schooled and switched to synthetic every 3000km
so whats the best oil to use? last time i got an oil change i forgot to ask. this time imma do it myself. if i get a flush ill buy the oil i want for them to use and do an oil change
its supposedly like the best of the best, its supposed to be really good. dont want to switch my motor oil but my mechanic said to use Royal Purple tranny fluid
get a tranny flush and use the purple power then.
brake fluid, power steering, etc. did the brake fluid a few days ago and i got my coolant changed with my engine rebuild
im not sure what the other bottles are, the Ice one looks like some kind of radiator additive, there looks like 2 of the same engine oils, 2 of the same tranny fluid bottles, and a multipurpose industrial oil/air compressor oil
its good now tho.
my power steering has a leak but its not work replacing the whole system yet
whatever dumbfukc did the coolant last (probably the last owners mechanic) used tapwater to mix with the coolant so my radiator is a bit screwed up as well but not that bad. Mishimoto makes 4th gen and up radiators but i might see if a 4th gen one can fit in a 3rd gen with little modding
Amsoil is absolutely the best. Beneath that, Redline and Royal Purple (IMO) are equals. Then, beneath those, you've got (not in any presumable order) Valvoline, Castrol, etc.....
ill look into amsoil when i go shopping for my oil. around how many miles do u change ur oil? do u do the traditional every 3000 miles?
http://www.mishimoto.com/mishimoto-p...ima-95-99.html
Personally, I change my oil when it begins to discolor, checking it at least once every two weeks after 2500 miles. I don't let my car go anymore than 4-5k miles on dino-oil. Given I bought my '03 with 120k miles on her and do not know the history of care, I've elected to not run synthetic in her.
However, I do run synthetic in my '89 turbo. Completely rebuilt, know the history, and less than 8k miles on the engine/turbo.
Amsoil is very costly, but is significantly more durable than other oils meaning fewer oil changes (depending on condition of engine). There is a thread in the Group Deals forum for Amsoil. Otherwise, you'll have to call around to some shops near you to find it, does not get carried often. There's only a handfull of places local to me that carries Amsoil, and that's due to me living near Bristol Motor Speedway.
imma start checking it like you cuz it makes more sense to change it when it discolors.
10+
http://www.marvelmysteryoil.com/
I've used it many times. The best product and recommend it to anyone.
i never did this b4 so i wouldnt know where to start.
Better acceleration, when I changed my oil, it cleaned my engine out took all that grime and dirt out. I poured some fresh oil and my car was good as new..Also I added it to my gas tank and it improved my injectors and everything. Plus this stuff been out for years. I used it on my old chevy. I recommend it to anyone, you can even youtube it if you want anymore proof. Really does work from the inside out.
each one has good ratings and reviews from my research
when u say u cleaned your engine, did u do it yourself? (like a flush) if so how did u do it?
or
did u get it done by a shop?
An old mechanic from my class told me this so I tried it and Im passing the info to others.
I did it myself, I added the mystery oil in my engine with my old oil, let it run for a couple of minutes..then let it sit overnight, the next morning I turned it on let it run for a while, then drained it. Man that thing was blacker than burnt toast. Changed my filter added fresh oil and voila clean engine.
ok i read this and now im sketchy bout flushing the engine
http://www.carbibles.com/engineoil_bible.html#flushing
