Please help me...need to get my car running asap
My car is running so terribly, I need to replace all of my injectors this weekend. Someone please explain to me how to identify my injectors so I can order new ones asap!! Its a 93 GXE
Should be a colored dot on the top of the injectors (green or yellow for a '93 GXE iirc). You might have to pop the connector from the injectors to see it. Order them from internetautosupply.com, he'll give you all of the necessary o-rings. The only other source for o-rings seems to be the dealership, as the o-rings listed at parts houses aren't the correct ones.
Call the dealer, and give them your VIN or exact production date and they can tell you which injectors you need.
Yeah you have to really b careful not to mix them up and get the correct dot color ones with new O-Rings, and a new upper plenum gasket. Believe me I changed one of my injectors( I was really impressed with my skills thanks to everyones help on this site) with a junkyard one that came from a gxe with the same oval top as mine. Put it all togather and pinched an o-ring. Took me three tries to get it right lol(actually 2 because on the 3rd try I only had to replace the plenum gasket.
Lakersallday24
Jun 16, 2019 01:35 AM
kjlouis
Nov 24, 2018 06:09 AM
