ECU Grounding.
Old Aug 28, 2010 | 10:46 AM
W00dface's Avatar
ECU Grounding.
Does anyone know if the ECU grounds through it chassis as I can't see a ground for it in the harness pinout I have. ( 94 vg)
Old Aug 28, 2010 | 10:56 AM
Chris Gregg's Avatar
Get Off My Lawn
Been a while since I've had my ecu open, but I recall that it does ground through the housing. The casing is NOT isolated from the bracket or the floor plan where it is mounted.
Curious.....Why do you ask?
Old Aug 28, 2010 | 11:15 AM
W00dface's Avatar
A few months ago I had a heater pipe leak in to the ecu. Damage was contained to a small area (around pins 60-57, 50-47 and a few components) The ecu is just showing a red LED and wont go in to diagnostics mode, engine wont start and conzut doesn't puick up the ecu.
Pulled the ECU, cleaded it and tried it again but nothing.
Have been really busy with no time to work on the car till recently so has been left till now.
I left the ECU outside it's chassis so was wondering if it grounded through it. Just put it back in chassis (not screwed in) and still the same single red light problem .
Can't get an ecu over in the UK for love nor money (well you can for £2100 from nissan !!!)
Old Aug 28, 2010 | 12:55 PM
Hectic's Avatar
My 91 foldout shows 9 ground pins at the ECU connector. VG of course, but I guarantee you the VE ECU does not ground out at the enclosure either. You kind of need the foldout to see everything clearly. If you can, print out all those pages from the PDF and line them up to get the full view. They should all be black wires, but that's not always the case with grounds.
Old Aug 28, 2010 | 02:26 PM
W00dface's Avatar
I printed that off. Trying to make sense of it. Electronics is not something I have taken much interest in before
Old Aug 28, 2010 | 11:04 PM
Augustus Maximus's Avatar
Why not get an ECU from off the org. I have one sitting around somewhere.
Old Aug 29, 2010 | 07:30 AM
Get Off My Lawn
I'll say you've shorted this ecu despite your ability to clean it and dry it.....especially if coolant got into the board...it's done. I wouldn't trust it at this point even if I could get it to work....know what I mean? I along with several others have additional ecu's you could use. Just email some of us or post a WTB thread in the 4 Sale forums.
Regarding the pins. I reviewed my tracing, and I can only find 7 that connect to ground points (89 VG). Not to dismiss the ecu is using these to help ground, all the points appear to be used to either obtain sensor signals/readings OR to sheild other wire signals (ie: if you've ever re-wired a MAF, there are ground sheilded wires inside). So, without cracking one of my ecu's, I still stand by my memory that the board does ground through the casing (This will drive me nuts, so I will be cracking one asap!). As Hectic mentioned, though, there are differences in the VG/VE ecu schematic. Sadly I cannot offer specifics on the VE as I do not have that foldout.
Hectic, just in attempt to figure out what you are identifying as ground points and hopefully learning something........the ONLY grounds I see running into the ecu are at points: 107, 108, 116, 10, 20, 50, and 60. And these all connect to F28 and F31 (engine ground points)respectively. Additinally, these are all black wires and there are NO other black wires listed off the ecu. This of course should compare VG to VG since that seems to be what you are referencing as well. However, what year foldout are you looking at? Again, mine is from an '89.
Old Aug 29, 2010 | 02:32 PM
Hectic's Avatar
It's a 91 FSM. There's actually 10, I missed one. The locations are 104, 107, 108, 116, 10, 20, 26, 30, 50 and 60.
Old Aug 29, 2010 | 09:03 PM
Get Off My Lawn
Wow, I did miss some. Those charts make my eyes go cross-eyed! Hectic, Much appreciation for pointing out the other black wires coming off the ecu. I know why I missed them now...... because I never marked them given they are not grounds. I originally needed a ground pin when connecting my Apexi AVC-r to the ecu, so I ignored all other "B" wire pins. But, there are definately other "B" wires!
The pin 104 is black and is a ground, but not for the ecu. Again, it's one of the many that are used to read signals/operate components. For example, 104 specifically runs to the fuel pump relay and fuel pump. Then 26 goes to the Airflow meter. Finally 30 goes to the Throttle sensor.
Still, my information is dead on correct pertaining to the pins I identified being the only ones which lead to an actual "ground" at F28 and F31.
So, Woodface, all the ground pins have been pointed out. Good luck....replace that ecu!
Old Sep 5, 2010 | 04:00 AM
W00dface's Avatar
one from a 91 should be fine shouldn't it? ie, this one http://cgi.ebay.com/ebaymotors/ws/eB...K%3AMEWAX%3AIT
Just want to double check as I don't want to wait 3-4 weeks and pay loads of import duty to find out it doesn't.
Old Sep 5, 2010 | 04:33 AM
That's expensive...you can find one on the org much cheaper. I have one that I have no use for, came out of a working 90 VG that I converted into a VE.
Old Sep 10, 2010 | 05:54 PM
Hectic's Avatar
True that, but 7 of the 10 are source grounds. Regardless, the ECU was exposed to water so it is no doubt fried, so I guess it doesn't matter. It is strange there are 7 input grounds though.. I guess there were layout/space restrictions preventing distribution on the mainboard.
Old Sep 11, 2010 | 08:52 AM
Hey old chap I found it and you can have it...not a fan of the VG at all!!!
Old Sep 14, 2010 | 10:20 AM
W00dface's Avatar
Cool. Are you ok to post it to UK. Will obv cover postage and don't mind giving you something for it. Just let me know how much it will all be and how you want payment
Old Sep 15, 2010 | 03:54 AM
Send an address...so I can get a quote from the PO.
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
Dasmith
Sep 23, 2015 08:28 PM
QueensMAX
Sep 15, 2015 04:14 AM
