My Clutch Gone ???
My Clutch Gone ???
Hey all.... recently... my car has been a pain to drive...
for a while now... i have expirienced loss of RPMS when the car gets to 2500 and above.. up hill or when i force the gas.. the RPMS will jump .. car doesnt really get effected. and from there on .. the gears started getting hard to switch into. now the latest is i got in to my car ( 91 Maxima SE ) last night ...
and press the clutch .. and my foot dropped ! .. i had to pump the clutch so i can even be able to barely put it in first gear and go from there.. clearly its bad.. what could be the problem .. oil ? pressure ? or just the clutch is gone?
Let me know if you have any insight because.. if the clutch is gone .. i might need to part ways with the car
(( ![bawling](https://maxima.org/forums/images/smilies/bawling.gif)
![Mad](https://maxima.org/forums/images/smilies/mad.gif)
Thanks all !!!
![Frown](https://maxima.org/forums/images/smilies/frown.gif)
Thanks all !!!
Are the clutch cylinder or the clutch slave cylinder hard to replace ?
Is it something that i can do myself ? or i will need to go to a mechanic ??
It seems like as im reading some of the posts around here.. that those 2 are the usual suspects of the cause for the clutch not to engage. if anyone has a simple write-up link let me know it will be very helpfull and i will try to do it myself as it seems not to be that hard .
THANK YOu !
THANK YOu !
no dumb questions ![Smilie](https://maxima.org/forums/images/smilies/smile.gif)
but for a 91 with 200k miles on .. sometimes is better to stop putting money into the car, because it really is going to be a waste
dont get me wrong i love my maxima ... i would hate to have to part ways with it ... but if i have to spent 500 to fix it.. id rather not because its just probably worth about that much anyway !
200k? lol
I wish mine had 200k on the clock. 263k, and still climbing, and that number is weak in comparison to the high mileage club.
yeah, I'll lowball augustus, and offer $225, and literally have my niece fix it.
edit: here's your writeup, the entire clutch section from the FSM.
http://www.nicoclub.com/FSM/maxima/1994/cl.pdf
two bolts, and a hydraulic line on each of the master and slave cylinders. also includes adjustment and bleeding procedures.
Don't remove the connector block there was a purpose for Nissan to put it there don't listen to others saying remove it. Im replacing all the clutch system from master to slave with all new lines and parts inline with the beginning and end of the clutch.
No don't remove it. I just have my clutch going straight from the master cyl to the slave cyl. instead of from the master cyl to the block then to the slave cyl. Makes bleeding the clutch a whole lot easier. I believe its other purpose is for the brake booster. Not 100% on that. James 92SE has it done ask him.
Thank You ALL for the helpful information .. saved me alot of time and troubles.
I got down to it and with your help was able to navigate through and get it going .. i am going to replace both pieces now. i have everything apart and have drained the fluid too. so tomorrow will put everything back together.
Thank you again !
Thank you again !
Did doing this fix your problem, please tell me or email me at (jonshivprashad@yahoo.com) thank you. My clutch only works like an 2 inches off the floor, like if i have to move up in 1st gear to park, I have to keep pumping the gas!
either you have air in your lines or you need to adjust at the pedal.
It's there for bleeding purposes...I think I should remove mine when I swap the gearbox.
I've removed that block and jumble of extra lines on all my VEs. That block is nothing but a total PITA for bleeding purposes (and actually makes it more difficult to bleed, if anything) and also some BS about pedal feel.
Slave cylinder, to s/s line, to steel hard line, to master cylinder all the way baby!
03-12-2020 12:06 AM
spencerwh1
06-30-2016 05:44 AM
carlosvq30
09-26-2015 09:44 AM
