Check Out This Clean 93' SE With a VE
Old 02-04-2011 | 10:27 PM
  #121
Augustus Maximus's Avatar
Originally Posted by madmax123
well i finnally got the motor and trans all hooked up and the wiring a/c only need the heater hoses hooked up and the transmission shift linkages
Did you change the heater core or do you plan to force on the smaller hoses.
im guessing that all the wiring for the fuel pump i do at the fuel pump correct or not.
At the pump and in the trunk.
Old 02-05-2011 | 06:21 AM
  #122
madmax123's Avatar
I left the oem heater core what im going to do is by the reducer to take the hose from 5/8 to 1/2 inch i also used the same a/c lines to i was able to get them just right without rubbing the motor im waiting on the drivers side transmission output shaft seal i had to order from rock auto no other parts store here even had a picture of it or the right one.
Old 02-05-2011 | 06:24 AM
  #123
madmax123's Avatar
is the safety relay in the trunk that i have to cut out? i need to look at the diagram better. or is it easier to use a higher output pump in the original housing.
Old 02-05-2011 | 06:41 AM
  #124
Just look at the donor car it's all right there. And just use the VE pump and sending unit.
Old 02-06-2011 | 01:42 PM
  #125
madmax123's Avatar
well it turns out i didnt need to by pass the fuel pump safety relay it crunk up with it all connected the only problem i have is that the key isnt starting the car everything is turning on im jumping it at the starter solenoid. i guess im gonna have to see what the problem is there other than that it runs.
Old 02-06-2011 | 11:04 PM
  #126
Good job...show us pics.
Old 02-07-2011 | 08:42 AM
  #127
shiloh51933's Avatar
Yes, some pics would be nice.
Old 05-05-2011 | 08:50 AM
  #128
There now selling the 93' Max with the VE with 68,000 miles for only 2100.00
Old 05-05-2011 | 03:15 PM
  #129
dead2fall's Avatar
Originally Posted by jeremeep
mines got 73k
body = 125k
engine = 450.0 ... not thousand hundred
Old 05-06-2011 | 12:34 AM
  #130
Yy
Originally Posted by dead2fall
body = 125k
You mean to say a brand new motor witj 450.0 miles, nice.
Old 05-16-2011 | 11:44 PM
  #131
An original owner wants to sell me his black VE, with low miles, in mint condition. If only he would drop the price.
-ReLLiK-
04-29-2016 07:25 PM
Maximan190
12-16-2015 07:01 AM
aminus21
09-12-2015 05:53 PM
crazyespn
09-03-2015 02:30 PM
