Car Running Rough At Low RPM & CEL (Injectors?)
Old Dec 4, 2010 | 03:00 PM
eM16's Avatar
I have a 1991 Maxima SE. 205k miles.
http://www.youtube.com/watch?v=SUpB206E1x8
Read the description there.
Can anyone help me out here? Injectors maybe?
I was thinking of running some BK44k and a full tank of gas maybe?
Old Dec 4, 2010 | 05:04 PM
jeremeep's Avatar
that would probably do the trick, probably just a clogged injector or something.
Old Dec 4, 2010 | 06:09 PM
jbbons25's Avatar
It looks like you started the car while the engine is cold. It should be that high when it's cold and the RPM should start dropping as the car warms up.
Did you ever recover the code from the check engine light you got you mentioned in the video description? That may be a start.
Try adjusting the IACV. When I replaced an injector a while ago, my idle would be around 1000 RPM with the engine running warm. I did the adjustment and it's idling fine now.
Old Dec 4, 2010 | 06:57 PM
eM16's Avatar
I never did because it's not currently licensed or insured.
I'm not exactly sure how to do the IACV (new to working on cars).
But something tells me its the injectors so I'm gonna run the Seafoam tomorrow, then maybe do an oil change.
Old Dec 4, 2010 | 07:49 PM
BenStoked's Avatar
Jesus was a Zombie.
don't seafoam.
you have no license/insurance, and can't get on it hard. Part of the process of seafoam is to drive the **** out of it after treatment.
and it's a dud injector, dude. just like you've been told in the other thread. unless the injector(s) is (are) gummed up from sitting for years, seafoam/bk44/viagra aren't going to clean a bad electrical system.
(note: not opposed to seafoam, just did it on my car today. just sayin' it won't help the OP, right now)
Old Dec 4, 2010 | 07:59 PM
eM16's Avatar
So how do I figure out which injector? Can I just replace one?
Old Dec 4, 2010 | 08:01 PM
jeremeep's Avatar
Originally Posted by BenStoked
don't seafoam.
seafoam helped me
plus new plugs, wires, distributor cap, rotor, etc..
Old Dec 4, 2010 | 08:49 PM
maximo018's Avatar
Start car and let it warm up to operating temp. Go one by one and unplug the injectors. You should hear the engine idle die a lil. When you hit the bad one idle will not change. For those in the rear under the intake try unpluging corisponding spark plugs. This is how I do it.
Old Dec 4, 2010 | 08:59 PM
eM16's Avatar
I was trying but I couldn't figure out how to unplug the injectors
Old Dec 4, 2010 | 09:13 PM
BenStoked's Avatar
Jesus was a Zombie.
just pull the wire for the spark plug. the injectors shouldn't just unplug (a couple of mine do, but like i said, shouldn't), because of the clip that's on 'em.
Old Dec 4, 2010 | 10:18 PM
eM16's Avatar
So start the car and for each spark plug wire I pull that it dies a little is the bad injector? Can there just be a few bad injectors (IE only injector 2 and 4 are bad and I can replace those)?
Old Dec 4, 2010 | 10:31 PM
CMax03's Avatar
No that means that 's a good cylinder that was making power. The one that doesn't show an RPM change are dead cylinders. Test your water temp sensor first is what I would do......
Old Dec 4, 2010 | 10:37 PM
eM16's Avatar
Everyone I talk to seems to think it's injectors. I'll try it first.
Old Dec 4, 2010 | 11:09 PM
CMax03's Avatar
usually it is injectors....especially @ 20 yrs young.....
Old Dec 5, 2010 | 12:47 AM
maximo018's Avatar
I'm replacing all mine. I don't fell like going back later to do this again.
Old Dec 5, 2010 | 10:18 AM
eM16's Avatar
Yep, confirmed. Fuel injector # 2.
kjlouis
Nov 24, 2018 06:09 AM
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
Maxboy23
Aug 11, 2015 11:59 AM
