Wheel Bearings...?
Old Feb 9, 2011 | 11:47 PM
Infam0usMax's Avatar
Wheel Bearings...?
*Bearings*- typo...
Well I got my OEM wheels back on the car now and when I get up to about 50-75mph on 195/60/15s $313 brand new tires... the front passenger side has my car shaking really bad but its only when the car is going str8 or the wheel is turned to the left... when I turn to the right its all good... not sure what the problem is...
Old Feb 10, 2011 | 05:34 AM
BenStoked's Avatar
Jesus was a Zombie.
sounds like it could be a bearing. could also be a tie rod, or a ball joint, or bushings.
jack the car up, give the wheel a wiggle.
Old Feb 10, 2011 | 06:08 AM
nc90gxe's Avatar
i'm going to vote for control arm bushing. not a terrible job just make a bushing removal tool or use map gas, hacksaw and some patience both work.
Old Feb 10, 2011 | 07:30 AM
Matt93SE's Avatar
STFU n00b!
what they said. groaning/growling noises + vibrations are usually wheel bearings. just vibrations are usually bushings or joints.
Old Feb 10, 2011 | 08:14 PM
how about none of the above this time guys... Someone had to come in my yard and messed around with my ride... the wheel wasn't tight and a lug was missing... it was holding on with one lug believe it or not... but thanks guys
Old Feb 10, 2011 | 08:27 PM
elusivemax93's Avatar
Time to buy locking lug nuts
Old Feb 10, 2011 | 10:11 PM
jbbons25's Avatar
The OEM size tire should be 205/65. You got some small tires.
But also, since they're new tires, balance issue?
Old Feb 11, 2011 | 01:35 AM
Yeah i know what the stock tire size is but I didnt want them... thanks tho and the problem is already sloved...
Old Feb 11, 2011 | 01:36 AM
funny you say that because all of the others have locking lugs on them this just happen to be the only one that doesnt and I dont know where it is
Old Feb 11, 2011 | 06:31 AM
Matt93SE's Avatar
STFU n00b!
You sure it was someone else, or did you just forget to tighten the lugs on that one wheel? It's okay... we've all done it before.
I even had to replace the fender on my S14 cause I lost a wheel. fortunately I was only a block from the house and was able to fix it in 15 min- other than replacing the fender.
Old Feb 11, 2011 | 07:13 AM
nc90gxe's Avatar
I've got to do better, I always think the worst with these cars and honestly they're not that bad once things are fixed.
Old Feb 13, 2011 | 11:54 PM
CMax03's Avatar
Was that a test???? My reply b4 reading your find was to jack the b1tch up and inspect everything for tightness and security.....that's pretty bad when you had to make a thread for some loose nuts......
HOKUSMAX
Nov 13, 2017 04:34 AM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Cipitiox
Wheels/Tires
Sep 30, 2015 06:16 PM
Andy29
Sep 29, 2015 05:32 AM
