where to get 16x8" wheels with a +35 offset?
yea im looking for some 16x8" wheels with a +35 offset... no luck for what im realling looking for
im kinda looking at the rota grid, but it doesnt come with the right offset, it only has either +45 offset or a +10 offset... can i fit the +45 on our cars lowered? with a 255/45/16? i need something fat to toss on there for some traction
anyone know of some wheels that are 16x8 with a closer offset? or how to make those fit? thanks
I ran ssr gt1's with a 245/40/18 and only the rear rubbed with passengers, the front was good, but I did have spacers.
I'm just thinking a +45 is going to push it WAY in...
I might need to go extended studs and big spacers, like 1.5" or something, I just want it to be safe, dont want to ride my rotors down the street,
So u think some 16x8 +45 will fit with a spacer?
255 is a lot of tire on an 8" wide wheel (on a car). I have 245's on an 8.5" wheel and the side wall is flat. I am running 16x8.5"s +37 with 245/45/16 tires all the way around with a 10mm spacer on the rear, and my fenders are rolled. +45 wheel with a 255 tire will rub on the inside for sure. I think if you can find what you are looking for, they should fit with no modifications assuming you use a more normal tire size for an 8" wide wheel. Personally I would not run something wider than a 245 on that size wheel...but that's just me.
These are my 225/45/17 on a 7" or 7.5" wheel...They're wide enough and hold a good line during high speed manuvers....no rubbing/bottoming out with back full of average weight folks but place some big 250 lbs+ ***** at least 3 and it will bottom out on the bumpstops but never no tire rub.....
tires i was looking at - http://www.tirerack.com/tires/tires....GFSP&tab=Sizes
wheels im looking at (16x8 +48) - http://www.machiii.net/index.php/whe...lipstream.html
think this setup will work with some spacers?
^ I can just imagine those on a 3rd. Unsure about 3rds, but +48 is a high offset for Maximas in general. Spacers are key. I have some for sale if youre interested. 25mm and 15mm.
Andy29
09-29-2015 05:32 AM
DC_Juggernaut
09-28-2015 04:07 PM
