going crazy
Old Mar 27, 2011 | 04:30 PM
tothemax2003's Avatar
going crazy
i dont know what else to do, my car has being running perfect until two days ago.It started when my dash went out, ofcourse i first check the bulbs and sure enough i had a burnt bulb.I then turned the lights on and it burned my number 10 a fuse, well it just keeps blowing the fuse.Thing is that the rear light assemblys were all changed they are pretty much brand new.And pfcourse the dash lights up when i brake without having the headlights on.Any help would be appreciated .
Old Mar 27, 2011 | 08:41 PM
MaxandAlt's Avatar
Have you tried your rear side marker lights? I just got my 93VE and kept having the same problem! Changed the lights and the fuse kept blowing! The only thing is that my dash lights didn't light up at all. I checked the rear side marker lights and both were out. Replaced, and Maxine lighting up like new again!
Old Mar 27, 2011 | 09:26 PM
maximo018's Avatar
Most ppl have this issue. The sockets for the rear tails usually have some corrosion build up. Just clean and use dielectric grease.
Old Mar 27, 2011 | 09:37 PM
CMax03's Avatar
pull all your bulbs out and see if it still blows a fuse! If it still blowing the fuse it's more than likely in the harness....Any drilling done recently???? Sounds like you hit your harness!!!!
Old Mar 28, 2011 | 05:52 PM
thanks found the problem light bulb making ground , my friend changed the light bulb all is good.
Old Mar 29, 2011 | 06:41 AM
CMax03's Avatar
Wowwwww! All that from that................?
ivorton23
Sep 28, 2015 09:08 PM
Garrettz459
Sep 28, 2015 02:50 PM
ColdCananda
Sep 20, 2015 10:45 PM
Maxima30
Sep 7, 2015 06:13 PM
Garrettz459
Aug 29, 2015 02:18 PM
