Passenger high beam prob
Old Jun 3, 2011 | 06:14 PM
Laevateinn's Avatar
My 93 SE's passenger high beam doesn't work. When I activate the highbeam switch or the flasher, it doesn't light at all. But the low beam works. I just changed the bulbs and it didn't solve the problem. What are the possible causes of this problem? Is it possible that the light socket is the culprit?
I've read some threads similar to this but they say that it's the signal switch itself (http://www.autozone.com/autozone/par...er=349477_0_0_). It costs $87 in Autozone. If this is the case, how will I replace it?
Old Jun 3, 2011 | 09:23 PM
BenStoked's Avatar
Jesus was a Zombie.
almost definitely a switch, it's the problem of 99% of the headlight problems.
hit up the classifieds, find a partout.
swapping it is an easy job, requires a phillips screw driver as the only tool, iirc.
Old Jun 3, 2011 | 09:52 PM
Laevateinn's Avatar
SO the wirings don't have anything to do with it?
If so, after I remove the column cover, are there any other things to remove to access it?
Old Jun 3, 2011 | 10:12 PM
maximo018's Avatar
Not that I can remember.
Old Jun 4, 2011 | 12:07 AM
Maxtastic GXE's Avatar
I have the opposite problem,if my turn signal arm is not perfectly centered the DS high beam will go on by it self! I've had quite a few dead battery mornings cause of this,so i ahve to push the arm forward to keep this from happening. ugh
Old Jun 5, 2011 | 05:40 AM
Maxkiller's Avatar
+1
Old Jun 5, 2011 | 11:39 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
bit driver is usually too big to fit into the steering column cover... so a proper screwdriver is a must. and the one tool i could never find every time i needed to take my bottom cover off
Old Jun 6, 2011 | 12:20 AM
Laevateinn's Avatar
I had that problem before, especially for the 5th screw near the back.
Anyway, I just want to make sure that it was the switch before spending ~$70 for a new switch. I'm not sure if this has something to do with it, but sometimes when i signal left while the steering wheel is pointed to the right, it feels hard to push it down and it doesn't feel right when I got it to that position.
Old Jun 6, 2011 | 05:12 AM
BenStoked's Avatar
Jesus was a Zombie.
every car I have driven that has a mechanical turn stock has done that to me at one point or another.
Old Jul 26, 2011 | 07:45 PM
shootingxblankz's Avatar
the switch is the problem i has it before.
user 11122324
42
Jul 18, 2022 03:35 PM
DJLAX152
May 4, 2021 11:46 AM
AaronL
Nov 15, 2020 11:52 AM
Maxima.KsA
May 15, 2020 04:14 PM
spencerwh1
Jun 30, 2016 05:44 AM
