Looking for a part...
Someone pulled out the front RH window forcefully so the rear clip that attaches the window to the regulator snapped into 2 pieces. fortunately, 93 maximas has an alarm if you open the lock manually with the door closed and nothing was stolen. Anyone knows this certain thing that I'm talking about? I need one. If anyone has a spare, would you mind post a pic of it and the cost to ship it in 92504.
You could always check a local wreck yard. I see more then a handful of 3rd Gens in pull part yards around where I live. You can even call most before hand and ask if they have one in the yard so you don't waist your time.
My I30 had a similar problem after the car was broken into. I had Techniglass replace the window but after about a month the clip holding the glass in place snapped causing my window to do a similar issue. Luckly I found a 4th Gen Maxima in a local yard and was able to get a new one.
unfortunately those clips aren't actually a separate part.. they are bonded to the window unless they break. you'll need to go to a JY and grab an entire window, which even so shouldn't be all that pricey. you can see form this pic that they are not separate parts.
picklepepper23
May 21, 2015 09:05 AM
karlsnissan
Feb 7, 2015 04:44 PM
