shaking problem
Old Dec 30, 2001 | 02:20 PM
nstymax93's Avatar
shaking problem
i have a 93' SE and when im stopped and the car is in gear the car shakes (vibrates) but if i put it in nutreal it stops. also the car stalls every now and then when i stop. Anyone have any ideas or similar problems and had fix? Any info. would be appreciated! thanks!
Old Dec 30, 2001 | 02:30 PM
brubenstein's Avatar
The idle speed is too low because the TB/intake is full of crud.
Old Dec 30, 2001 | 08:11 PM
superdesi's Avatar
Brubenstein, where have you been. You are the ORG's hailed transmission guru.
The only thing that solved my vibration issue was replacing the motor and trans mounts. The dramatic difference was felt in the driver's seat....sometimes I had to rev the engine just to make sure it was running.
Old Dec 30, 2001 | 08:38 PM
Umm, I needed a break from the same questions over and over...
Anyway, in the original post it also said, "the car stalls every now and then when i stop". This means there is something wrong with the way its running. Not that the motor mounts aren't bad, but I'd check the basic engine stuff first.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
