Replace a leaking oil pressure switch
Old Jan 28, 2012 | 06:34 PM
bluewater's Avatar
Hi, I need to replace a leaking oil pressure switch for my 92 SE. Has someone done this without taking out the alternator? If yes, please share how you did it. Thanks in advance.
Old Jan 28, 2012 | 06:41 PM
akurtzer57's Avatar
Its on the back of the block by oil filter. Not even close to altenator that is on front of motor.
Old Jan 28, 2012 | 07:16 PM
bluewater's Avatar
I have jacked up the car today and seen the oil pressure switch is up frond and next to the alternator. The oil filter is in the front for this year model.
Old Jan 29, 2012 | 12:43 AM
jbbons25's Avatar
Not on the VE. The oil pressure switch is located on the front of the vehicle.
By looking at photos, it looks like it could be difficult to remove it without moving it. What you can try is remove the adjustment bolt on the bottom and move the alternator all the way up to see if you can get enough room to get to the switch.
Old Jan 29, 2012 | 01:32 AM
CMax03's Avatar
Use a boxed end wrench.....
Old Jan 29, 2012 | 03:25 AM
maximo018's Avatar
Well we know which motor you have.
Old Jan 29, 2012 | 10:42 AM
bluewater's Avatar
Is it correct that all the 3rd gen SE model uses VE30DE engine?
Old Jan 29, 2012 | 11:14 AM
jbbons25's Avatar
Only the 92-94 model year SEs have it.
Old Jan 29, 2012 | 02:41 PM
bluewater's Avatar
Got it. Mine is a 92 SE. Thanks.
Old Feb 6, 2012 | 06:31 AM
bluewater's Avatar
Changed the switch. It is very easy...all you need is a 27mm or 1-1/16 inch deep socket. There is enough room to put a socket on top of the switch.
MaximaDrvr
Aug 19, 2015 08:20 PM
scarletsosa
Aug 17, 2015 09:09 PM
acw
Aug 13, 2015 12:50 AM
Balkins
Aug 12, 2015 06:39 AM
acw
Aug 7, 2015 04:20 PM
