Pop trunk not working, any ideas?????
Originally posted by MONTARABOB
There is a valet lock out...open trunk, look down, the striker on the
body. See the bolt holding it in? See the hole just to your left?
There is a lever, UP to allow button to work, DOWN=button no work.
what is the striker on the body???
What tool do you suggest?
Originally posted by Mikes90GXE
Adjust the striker in the body of the trunk so that it is in the center of the trunk lid part as the trunk lid closes. If it is out of adjustment, the solenoid will not release the latch.
mine didnt work after i did trays one time.. my sub hit the back and bend the peice the trunk latch goes into so it knocked it off track.. maybe somethig is bent in yours.. or adjust that latch that diables the electric release..
Is it easy to access?
The part that you adjust is NOT in the trunk lid, but in the body of the trunk between the tail lights. You need either a screw driver or a bolt driver - I forget.
Re: Re: Re: Is it easy to access?
Originally posted by Valadez_jr
Thanks for the advice. I'll have to adjust it this weekend
Re: Re: Re: Re: Is it easy to access?
Originally posted by platinumplus
If you say that your keyhole is shaved that means the only way to get access into the trunk is by removing the back seat. Its fairly simple, the seat pops off. After that remove the aluminum bar behind the seat and climb into the trunk. When you press the button for the trunk under the door armrest do you hear it clicking?
sorry for resurrecting an old thread...
but I have a similar problem in my '94 max. My trunk keeps trying to open (click click click) the button on the door doesn't do anything, and even though the trunk tries to open, it really doens't. I've tried fiddling with the switch and what not, but it hasn't seemed to do anything.
Is there a fuse to disconnect the pop trunk from working altogether? Anyone know which fuse that is in particular? Thanks!
Maybe I can shed some light on this thread. I have the same problem in my 94 GXE. The button on the door makes the clicking noise in the trunk and the trunk won't open. THe key still opens it and like you guys said, if someone presses on the trunk while i hit the button, it will come open. When i went to investigate, I found that the part that releases from the latch (the part on the trunklid itself) has a spring on it that had broken and was hanging loose. my guess is that this is your problem if the alignment is OK. Hope you get it working. Mine's been broken for about a year now.
Peace
Peace
Clarify?
I have the same problem, the little switch that you push down for Vallet falls down on its own. I can pull it up and it will work for a couple of days then it wont open and I have to use the key again to open and pull the lever up. What kind of adjustment can be made to keep it from falling, or am I missing some kind of spring. Ideas or pics would be greatly appreciated!
Thanks,
Thanks,
King_Ten_Ahead
Sep 30, 2015 04:27 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
FanaticMadMax
Aug 10, 2015 08:55 PM
