My shaking problem
Old Jan 4, 2002 | 09:26 AM
hclll's Avatar
My shaking problem
Hey guys, I went to a mechanic today and he said the shaking problem is due to the engine mount. He said there are 3 totally, to replace them $100 each.
Is the replacing work labor intensive? Or this problem could be tranny mount? I noticed it becomes harder to shift from R to P than before.
Thanks.
Old Jan 4, 2002 | 09:38 AM
Matt93SE's Avatar
STFU n00b!
there are actually 4 mounts. 2 engine mounts, and 2 tranny mounts.
the engine mounts aren't bad to change- they'll take about an hour for both. jack up car, support engine, remove lower crossmember and engine mounts as a set. change the mounts, replace.
(sounds easy, but try to move a 600lb engine 1/4" while you're flat on your back under the car)
tranny mounts aren't bad either, but they're a little different trick than the engine mounts.
user 11122324
42
Jul 18, 2022 03:35 PM
Need help
23
Oct 2, 2015 08:56 AM
Noela
Sep 26, 2015 08:22 AM
homewrecker
Sep 24, 2015 07:01 PM
