One headlight brighter than the other
Old Jul 3, 2012 | 04:28 PM
majordan's Avatar
Any suggestions as to why this happens. I have had this problem forever. Also, one side of my low beams always burns out before the other side. I usually end up just leaving them on high.
Thanks in advance,
Old Jul 3, 2012 | 06:15 PM
Hectic's Avatar
Check housing alignment and voltage on each side. If there is a substantial difference in voltage, replace or rebuild your switch.
Old Jul 4, 2012 | 07:57 AM
James92SE's Avatar
2 VE's are better than one!
Well that's certainly courteous to your fellow drivers
Old Jul 4, 2012 | 10:14 AM
majordan's Avatar
Hector
Do you mean the switch on the steering column?
Old Jul 4, 2012 | 10:15 AM
majordan's Avatar
Sorry, I meant Hectic.
Old Jul 4, 2012 | 04:50 PM
T_Behr904's Avatar
I've had headlights go dim before, and it's always been caused by a bad ground. I recently fixed a ground wire on my mom's Blazer headlight due to that. It was on, but it was dim.
Old Jul 4, 2012 | 08:20 PM
internetautomar's Avatar
mod or sell?
run new grounds to each bulb.
Old Jul 18, 2012 | 09:13 PM
CMax03's Avatar
wiring to connector is wrong or you have a frayed up light bulb connector harness!
Old Jul 28, 2012 | 10:14 AM
majordan's Avatar
When you say run a new ground to each bulb, do you mean splice the black ground on the back of the harness connector with a new ground wire and attach to chassis?
Old Jul 28, 2012 | 12:22 PM
BklynsmoeVE's Avatar
Ive also noticed this is a problem i have...i just assumed the houseing allignment was off like what hectic said. Can anybody just flash one headlight by veryyyy gently clicking the high beam...i thought all 3g's had this trick? Heh..i hope someone knows what im tlking about.
Old Jul 28, 2012 | 10:07 PM
maximo018's Avatar
Have you swapped out the stock connectors for high temp connectors? I onow they are prone to melting and other issues. I swapped my to prevent any issues I might have. Maybe you could try this as an option. Probably gonna have to do so eventually. Better to know now then be surpised later.
Old Jul 29, 2012 | 12:19 AM
majordan's Avatar
How do you run new grounds to each bulb?
Old Jul 29, 2012 | 04:46 AM
Hectic's Avatar
You can start by using a couple quick splices on each bulbs ground wire, connecting them in parallel (Y), then connect the other end directly to the negative terminal on the battery.. This to confirm it's actually a bad ground, which I highly doubt it is. If that doesn't work, then look towards replacing the headlight switch.
Please don't call me Hector
Old Jul 29, 2012 | 12:52 PM
majordan's Avatar
Thanks Hectic
Old Jul 29, 2012 | 11:50 PM
Hectic's Avatar
No problem, JK about the Hector bit, I didn't even notice you corrected yourself.
If the test wire doesn't solve the problem, inspect the connector terminals for corrosion or damage before moving onto the switch. You can look up the correct ground point as well in the FSM. Look for the code next to the ground symbol in the headlight wiring diagram, then you look up the code in the layout in the back of the manual which will show the location.
doctorpullit
Oct 28, 2019 10:58 PM
trsandrew
Oct 25, 2015 02:47 PM
Dennis Twohy
Oct 1, 2015 06:01 PM
Noela
Sep 26, 2015 08:22 AM
