Sensor in bottom of tranny
Old Sep 2, 2012 | 09:47 AM
woot's Avatar
So I've searched the Chiltons manual front to back several time looking for this part,but I could not find anything.
Can someone please fill me in on what this part is called?
I'm working on a 90 model Se.
It is a round sensor on the bottom of the transmisson with a few wires running up beside the intake.
Mine is cracked and is leaking gear oil terribly!! Any advice or answers is greatly appreciated
Old Sep 2, 2012 | 11:42 AM
3rdGenFern's Avatar
Is it for the 5spd? if it is than i believe its the back up light switch that turns on the reverse lights.
Old Sep 2, 2012 | 11:50 AM
maximo018's Avatar
Exactly
Old Sep 2, 2012 | 12:04 PM
AznRyan's Avatar
I dunno much about tranny's bottoms Name:  shifty.gif
Old Sep 2, 2012 | 12:22 PM
maximo018's Avatar
Lol. Yeah. I would order one from Courtesy but if your funds are low then Orielly's has them.
Old Sep 2, 2012 | 12:29 PM
woot's Avatar
It is a 5 speed, I will check out the part and see what I can come up with. Thanks for the help!
Old Sep 2, 2012 | 12:48 PM
maximo018's Avatar
Its kool. Just unscrew the lil 10mm screw, be careful and use a flat head to slowly pry it out.(they are known to break easily) If you do break it like I've done in the past I use the cord to pull it out. Remember when you do this all the gear oil is going to drain out. Matter of fact this is how I drain my gear oil considering its the lowest spot on the trans.
MaxStock
Dec 5, 2016 05:19 PM
spencerwh1
Jun 30, 2016 05:44 AM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
Lowered_a33
Sep 1, 2015 07:49 PM
