window problem
Old Sep 19, 2012 | 08:29 AM
carlwp's Avatar
window problem
the driver side rear door power window quit working. i know nothing about power windows. i can hear the motor working when i push the switch and it appears to be on track. but the cable is loose like it came off a guide perhaps at the bottom. and the window can slide up and down freely. is there a diagram for cable routing ? any help would be appreciated.
Old Sep 19, 2012 | 10:05 AM
7mJoe's Avatar
Sounds like the regulator broke. It's very common. Pop off the door panel and have a look.
Old Sep 19, 2012 | 10:49 AM
tmorales509's Avatar
yeah regulator broke. I had to change all 4 of mine. You can get them for like $20 on ebay $30 with the motor.
Old Sep 20, 2012 | 09:47 PM
rmdl51's Avatar
White_Shadow
I have not done rears but I did both front on my Maxima with same problem, you don't need any wire routing, just buy the window regulator without the motor if you are sure your motor works good.
I removed door panel, take out some screws, remove window, unlatch some wire connectors, nothing complicated, it is very easy and this is coming from me which I'm a noob on cars maintenance for either electrical/mechanical issues.
I bought the window regulators from auto zone since they have lifetime warranty not bad for $42 each ( I can't find them on ebay for less than $30 without motor )
pears
Sep 18, 2015 05:25 AM
thenewguyy
Sep 12, 2015 11:12 AM
markevans999
Sep 10, 2015 04:29 PM
ef9
Sep 5, 2015 11:18 PM
