300z in a '90?
Old Nov 10, 2000 | 08:21 PM
Jon Little's Avatar
Can i put a 300z engine in my '90 SE, will it fit? Where do I find one? who will put it in? COST?
Old Nov 10, 2000 | 08:25 PM
Maximamike's Avatar
"Can i put a 300z engine in my '90 SE, will it fit?"
84-89 Z engine yes.
"Where do I find one?"
A "parts recycling place"
" who will put it in? COST?"
You will or your mechanic will. I don't know what he would charge.
Old Nov 10, 2000 | 08:31 PM
89GXE
VG30DE
I think you are refering to the VG30DE in the 90-96
Z-Cars & Infiniti J30's. It is a rear drive engine and
there may be some trouble with trans bolt patterns so
you might look at that. Other than that I don't know
why it would not work.
Old Nov 10, 2000 | 08:54 PM
wouldn't you be looking at a whole new drivetrain? I mean, can the stock Maxima trans take the abuse from a 300ZX (TT? or n/a). also, I would imagine there are different rears on the two cars, for obvious reasons....
my $.02....wait, its not worth THAT much
Chris
Old Nov 10, 2000 | 09:00 PM
89GXE
Trans
Get the trans out of a 00-01 max
Old Nov 10, 2000 | 09:10 PM
what do the new trans handle? 220hp and how much torque?
what numbers do the 300ZX tt put out?
Chris
Old Nov 10, 2000 | 09:18 PM
89GXE
Whoa!
I wasn't talking about a turbo' dang those turbo motors
are crammed in there in a 300 turn it sideways and it
is going to get worse.
Maximamike's Avatar
What the hell are you guys talking about? A newer 300zx engine will not fit. An older Z engine will fit. There is no tranny swaps necessary. The VG30E-T puts out like 220 hp or something..
Old Nov 10, 2000 | 09:26 PM
89GXE
VG30ET
The old turbos were closer to 200 hp. The VG30DE is
similar in size to a VE30DE used in the 92-94 SE's
Old Nov 10, 2000 | 09:28 PM
uh...220hp? I thought that was N/A
i thought it was 222 hp for 90 and up
and sorry for my ignorance on it being the SAME DAMN SHORTBLOCK.
stupid pistons.
i thought it was 300hp for turbo Z's
Old Nov 10, 2000 | 09:29 PM
Maximamike's Avatar
The VG30DE(TT) found in 90-96 300zx's is really freaking big. I doubt you could stuff that and the turboes in any Maxima(except a 1st gen one). But a VG30E(T) would fit fine with some minor mods..
Old Nov 10, 2000 | 09:32 PM
89GXE
Non Turbo
Mike I'm talking about a non turbo VG30DE not a VG30DETT
Old Nov 10, 2000 | 09:38 PM
Sith's Avatar
ok
a VG30DE with some cramping, lots of money, and the time, can fit into your max. And when N/A has hp around 200 - 220. The VG30DETT would, well lets, i believe the words Mikey said were *insert metal cutting sound here*. Not to mention i don't even think your intake manifold would work on it, and would have to have custom exhaust manifolds made.
VG30E-T like Mikey said is a good swap with minor mods. The easiest out of the 3 by far.
VG30E-T and VG30DE you would not need a new tranny, just beef your exsisting one up, unless it's shot then would have to be rebuilt, would probably be a good idea to rebuild it anyways.
Old Nov 10, 2000 | 09:46 PM
Maximamike's Avatar
90-96 300zx twin turbo=300 hp(Autos and 96's 280) and 283 ft lbs of torque.
90-96 300zx normally aspirated=222 hp and 198 ft lbs of torque.
^^^^^^^^^^^^^VG30DE(TT)^^^^^^^^^^^^^^^^^^^
84-87 300zx turbo=200 hp and 227 ft lbs of torque.
88-89 300zx turbo=205 hp and 227 ft lbs of torque.
84-87 300zx normally aspirated=160 hp and 177 ft lbs of torque.
88-89 300zx normally aspirated=165 hp and 177 ft lbs of torque.
^^^^^^^^^^^^^VG30E(T)^^^^^^^^^^^^^^^^^^^^^
VG30DETT=No go unless you have $$ to blow.
VG30ET=Good, cost effective turbo swap with hella potential.
VE30DET=Coming soon
Any questions?
[Edited by Maximamike on 11-10-2000 at 11:52 PM]
Old Nov 11, 2000 | 02:59 AM
MILLENIUM MAX
LMAO
I like mikey because he puts the turbo facts down and to the point.Now if you guys don't get it then i don't know what to tell youz.
Old Nov 12, 2000 | 06:59 AM
FAST4EN's Avatar
Re: LMAO
Or you could take into the fact that an engine swap that you're talking about would cost almost as much as a 91-on 300zx. If you want a Z engine, then get a Z!
Old Nov 12, 2000 | 03:48 PM
Nismo87SE's Avatar
Re: VG30ET
Dude the VG30DE is different from the VE30DE. The heads themselves are like twice as wide. At the austin meet Mr. Rose and I were taking measurements and eye balling the 92 300zxTT that was parked next to him with the hood up. If you were to drop in a VG30DE there would only be about 1 inch space between the heads and radiator/firewall. Also the VG30DE has a bigger intake manifold which no doubt gives it the power advantage. No a VG30DE manifold won't fit a VE30DE. Also there is the fact that the engine is around $1200+ and the labor cost. You'd be lucky to see if it bolts the the VE/VG tranny. The other quirk with the swap is that the most you could get from the engine without NOS would be around 200-210hp at the wheels. Even if you had the TB bored, heads ported with a valve job it would only gain you about 10hp over a stage III NA. Stage III NA mods are intake, ECU, pulley and exhaust. They increase the power from 180hp to like 200hp at the wheels. I'm sure a VE would get 200hp at the wheels with full bolt ons and alittle extra. As for a VG, unless your going with high compression pistons don't even think about it .
Old Nov 12, 2000 | 08:20 PM
SkyMax's Avatar
FAST4EN....
From reading your Mods list... how the hell do you have a Freedom Design RSTB???
Old Nov 13, 2000 | 10:43 AM
Maximamike's Avatar
Re: Re: LMAO
Originally posted by FAST4ENOr you could take into the fact that an engine swap that you're talking about would cost almost as much as a 91-on 300zx. If you want a Z engine, then get a Z!
Well, when you say it that way. If you want clear tails, buy a Civic..
Old Nov 13, 2000 | 10:55 AM
Matt93SE's Avatar
STFU n00b!
Re: Re: Re: LMAO
that's where they belong.. leave them there.
YUTAKARNB
May 31, 2003 12:30 AM
CHAZMAX
Jan 29, 2003 07:14 AM
SmithAtlanta
Jul 3, 2002 05:01 AM
JPMontoya
23
Apr 16, 2002 04:59 PM
