Low Beam Headlight Problem
Old Dec 14, 2012 | 02:09 PM
NBD925's Avatar
I have a 1993 Nissan Maxima and the Low beams are both out. I have a few new bulbs and they dont work either. The High Beams work great. I have checked power to the headlights and the highbeams are 11.9v and the low beams when i activate them are 0.00v I checked the combination switch and cleaned the contacts with light sand paper. I checked the two fuses next to the battery in the fuse box still nothing.
Where do I go from here? I just cant get any voltage to that low beam wire.
Old Dec 14, 2012 | 07:33 PM
BenStoked's Avatar
Jesus was a Zombie.
I would advise checking the switch for continuity on the low setting. Despite the pins being cleaned, they may not be aligned, or bent during cleaning.
Do you have a DRL system, or aftermarket alarm?
Old Dec 16, 2012 | 07:33 PM
NBD925's Avatar
Thanks I fixed it
I dont really even want to tell you what I was doing here to make this happen but I will, so no one else will be this stupid.
I had the damn Headlight switch on the Driving light setting with the lever full forward. So I would turn the headlight **** to driving lights and check low beam and then turn the **** to headlights on and check the High beam.
Holy Jesus!
Maxima.KsA
May 15, 2020 04:14 PM
MaxLife17
Jun 27, 2019 01:37 PM
markevans999
Sep 10, 2015 04:29 PM
MaxLife17
Sep 8, 2015 02:36 PM
TheMafia
Sep 4, 2015 08:26 AM
