Low MPG on a 92 SE
Old Dec 25, 2012 | 02:05 PM
bluewater's Avatar
Low MPG on a 92 SE
My 92 SE (manual shift) only gets 14 to 17 MPG. I don't press the gas pedal hard and use cruise control most of the time. What should I do to improve the MPG?
I have searched the forum for advice but only found bits of info. I am hoping someone had similar problem can share what you've done to improve the MPG. Thanks in advance.
Old Dec 26, 2012 | 08:48 AM
Levsimus's Avatar
Well best I can tell, these cars aren't setting any records, but mine is particularly bad due to vac leaks and a couple dead cylinders (injectors)
I'd check there if you're wanting to dig in.
Old Dec 26, 2012 | 08:51 AM
ghostmax's Avatar
Regular tune up stuff like spark plugs, timing, air/fuel filter change. Fuel injectors may be bad as well. Also if you haven't replaced your oxygen sensor, you could try that.
I have a 92 SE manual and get about 21-23 mpg in city.
Old Dec 26, 2012 | 09:29 AM
coolsun's Avatar
you checked your codes? when i had my 93 i changed the knock sensor, o2 sensor, and the rear seized calipers.
Old Dec 26, 2012 | 05:29 PM
bluewater's Avatar
I have changed spark plugs, air and fuel filter, vac tubes. Checked timing. And all the fuel injectors show the right Ohm readings. No error code.
I have not replaced the oxygen sensor yet...does it have an impact to MPG?
Old Dec 26, 2012 | 09:29 PM
jbbons25's Avatar
A bad/slow reading O2 sensor can affect mileage. If you haven't changed it in a long time, it would recommended to change it.
Also check the engine coolant temperature sensor, mass air flow sensor and their connections. Those two can also affect mileage.
Old Dec 28, 2012 | 11:41 AM
bluewater's Avatar
I still have the factory O2 sensor so I think it is time to change it. I have ordered the part.
I have checked the engine coolant temp sensor with an Ohm reading. It is in spec. Also changed the mass air flow sensor.
Hope the O2 sensor will make a difference on MPG.
Thanks for all the advise!
Old Dec 29, 2012 | 08:27 AM
CMax03's Avatar
leaking injectors more than likely......
aw11power
Oct 10, 2021 04:57 AM
ef9
Oct 4, 2015 08:43 AM
sliptap
Sep 30, 2015 05:57 AM
