Tps
Old Jan 15, 2013 | 08:04 AM
TonyJr's Avatar
Tps
Does a VG tps works for a VE motor.
Old Jan 15, 2013 | 08:22 AM
Greeny's Avatar
¯\(°_o)/¯
yep, one in the same...
http://www.courtesyparts.com/maxima-...1627_1628.html
Old Jan 15, 2013 | 12:23 PM
TonyJr's Avatar
Thanks just installed it n it works fine. Now my idle is steady at 700 rpm
Old Jan 15, 2013 | 12:58 PM
Greeny's Avatar
¯\(°_o)/¯
Old Jan 16, 2013 | 03:53 AM
maximagician's Avatar
iirc. you should adjust the tps since it has slotted screw holes
you could use a multi meter or
iirc. use the ecu mode for switches on\off and adjust it till the cel lights up right as you press the gas pedal (i think its the idle switch on\off adjustment as a reason)also,
those little special shaped screws WILL snap if overtightened there is no need there
Roymg
Sep 3, 2018 05:10 AM
schmellyfart
Sep 25, 2015 04:47 PM
sake1bs
Sep 19, 2015 09:32 PM
nizmolee
Aug 22, 2001 12:34 PM
