lack power
Old Feb 2, 2013 | 01:16 PM
stevex's Avatar
lack power
please help about:
while driving, car suddenly lack power. I push accelerate pedal but rpm drops. Then I stop, turn off engine, wait 5-10 sec, turn on engine and then no problem.
This problem repeat once in 3-4 days, not every time while driving.
sorry for bad English and I hope you understand my problem...
Old Feb 2, 2013 | 02:20 PM
chrome91's Avatar
which engine? VE30 or VG30?
Old Feb 2, 2013 | 02:35 PM
stevex's Avatar
Vg30e, mt
Old Feb 2, 2013 | 06:03 PM
chrome91's Avatar
hmmm hard to say, being so intermittent it could almost be a wiring problem or something with the distributor
Old Feb 5, 2013 | 08:29 PM
Chris Gregg's Avatar
Get Off My Lawn
Could even be a bad (failing) fuel pump, especially if the car is stalling, wasnt clear if you just stopped the car or if it would die.
Old Feb 5, 2013 | 09:52 PM
CMax03's Avatar
MAF or Ignition coil...was there any stumbling? Check your fuel filter for being possibly clogged.....
Old Feb 6, 2013 | 01:30 PM
stevex's Avatar
I forget to mention,
when problem start, idle rpm drops to 500 for about 3-4 sec and then back to normal (950 rpm).
about fuel pump... is that mean it dying or what...
thanks for answers
Old Feb 7, 2013 | 12:08 AM
stevex's Avatar
no, it not die. I stopped because rpm drops and there is no power even when push accelerate pedal. Sometime after 10-15 sec everything back to normal and sometime I just turn off engine, wait 5-10 sec, turn on and no problem...
Old Feb 7, 2013 | 11:48 AM
Get Off My Lawn
Could mean fuel pump is failing. But as mentioned, it could also be that your the fuel pick up screen in the case tank is pulling up debri and clogging the fuel intake. Once you shut off the engine, the debri falls back into the fuel inside the tank, then you restart and there is no obstruction until the trash/debri recollects on the collector screen.
Old Feb 7, 2013 | 02:03 PM
fiznowler's Avatar
It does sound fuel related. But could be other things as well so here are a few I would look at. I have also had a vehicle act like that and it had a nearly broken battery cable. I don't know if you are having anyother electrical issues but mine simply didn't have enough voltage to fire right but it would still run really weak. Also unplug your maf and see if it makes it run better. A bad or failing MAF could make it run horrible. Unplugged your car should be thrown into safe mode and at least idle alright.
Old Feb 8, 2013 | 09:26 PM
Houdini's Avatar
Check your maf. Solder joints go bad on the leads from the connector frequently on all old nissans. remove the square cover on the maf to inspect the joints.
gigabyte
Jan 6, 2017 06:05 PM
maxinout93
Oct 31, 2015 02:04 AM
leatherneck
Sep 30, 2015 09:16 PM
