Belts replace on ve30de
Old Apr 30, 2013 | 05:15 PM
TonyJr's Avatar
How do you replace the belts? When removing the axle I notice that the belt closes to the motor by the oil pan is in bad shape. I'm still waiting for my axle so I figure its a good time to replace now
1992 ve30de
Old Apr 30, 2013 | 05:16 PM
James92SE's Avatar
2 VE's are better than one!
Remove old belt. Replace with new.
Old Apr 30, 2013 | 05:28 PM
TonyJr's Avatar
There nothing I have to remove first. Or is it as easy as loosen the bolt that tighten it and replace the belt and retighten the screw ?
Old Apr 30, 2013 | 08:11 PM
CapedCadaver's Avatar
Call me Wookiee Goldberg
www.nicoclub.com/FSM/Maxima/1994
MA.pdf page MA-13. lrn2rtfm
Old Apr 30, 2013 | 08:13 PM
James92SE's Avatar
They're super easy man. You have to loosen the idler pulley nut, use the tensioner screw to move the idler pulley to get enough slack to remove the belt. Then install the new belt, use the tensioner screw to move the idler pulley back to tighten the belt, then tighten the idler pulley nut back.
The alternator doesn't have an idler pulley but it does have a tension adjustment arm.
This is an old UDP write-up, but it also explains how to replace the belts:
http://www.4dsc.com/articles/drivetrain/udp/udp.shtml
Old May 11, 2013 | 01:43 PM
maxima278's Avatar
My car is the same way. Windows go up but not down. My previous car, a VE auto, was the opposite. Two or three times I spent $5 at the local junk yard on replacement switches, and each time I ended up with one that was broken a different way.
Old May 12, 2013 | 01:53 PM
Laevateinn's Avatar
You might want to do the front main seal while you're at it. Oil and/or coolant will destroy new belts.
PH98I30
29
Feb 10, 2025 12:03 PM
mvm062
Nov 30, 2020 09:00 AM
dvcamp
Sep 18, 2015 10:17 AM
Maxima30
Sep 7, 2015 06:13 PM
boomerbrian
Sep 4, 2015 08:25 AM
