1993 Maxima Shifting Problem
Old Jun 5, 2013 | 11:14 PM
Maxima_Maima's Avatar
Can please somebody help me on this...I have a 1993 Nissan Maxima GXE I recently had a motor swap to the car and all problems have began.. My main problem that I have it seems like my transmission.. The car seems like its stuck in 3rd or second gear because when I am at 45mph I am at 3000 Rpm but when Im at 60-65mph I am redlining. The transmission feels strong but I cant under stand why it wont shift. Also while in Park or Neutral the idle seems to be a bit high at almost a 2 RPM until I shift it in gear and it drops down to below a gran. Could it be that the TCU has gone bad? Has anybody had this problem and can help me with this issue?
Old Jun 6, 2013 | 08:17 AM
shiloh51933's Avatar
Shoulda swapped in a 5speed while you were at it...could be issues with shift/lock up solenoids. If you search in 3rdgen forum there's a thread on how to test your A/T TCU for codes. My bad but I can't remember name of thread...maybe somebody will chime in with name of thread.
Old Jun 6, 2013 | 09:50 AM
That your right I should have went manual... but I hope its the solenoids I hope some one else can shed some more light. But thanks!
Old Jun 6, 2013 | 12:05 PM
jbbons25's Avatar
Getting trans codes starts at page 45. Make sure you have the P light on the AT switch working before checking for codes
http://www.nicoclub.com/FSM/Maxima/1994/at.pdf
Old Jun 6, 2013 | 01:25 PM
I dont have a check engine light does that make a diffrerence?
Old Jun 7, 2013 | 04:12 PM
jbbons25's Avatar
I don't recall. But since there's very little communication between the engine at the transmission, it may not matter if the check engine light may be on or not when there's a trans problem.
Old Jun 15, 2013 | 06:59 PM
Update:
1) The transmission fluid is full .
2) Changed the TCU and same thing
3)****I noticed that I didn't mention that the transmission shifts from first gear to second gear no matter what im in d1 or d2 or regular D...
here is my question is it possible the transmission was put in wrong when the engine swap took place?
Old Jun 22, 2013 | 12:13 PM
CMax03's Avatar
Was your torque contverter engaged in all the way?
Old Jun 22, 2013 | 12:18 PM
CMax03's Avatar
Are SOHC M/t and A/t engine mounts (just the two on the X-member) the same? I'm trying to order some from an aftermarket source and the trim difference is SE and GXE for the front and rear mounts....I'm not sure if the SOHC SE is a M/T or if a GXE is a M/T...I've seen both so thier system is kinda confusing!
Old Jun 24, 2013 | 01:25 AM
I dont know if it is what are the symptoms of the torque contverter not engaged in all the way? Wouldn't the car not move at all?
Old Jun 24, 2013 | 07:13 AM
DanNY's Avatar
Ad·min·is·tra·tor
you sure the shop plugged in all the connections correctly?
the solenoid and the rear bank injector has the IDENTICAL connector....remind me to shoot the nissan engineer that decided that was a good idea.
Old Jun 25, 2013 | 01:20 PM
Wouldn't the car misfire or give a check engine light?
Old Sep 20, 2013 | 01:04 PM
Problem fixed!!!
DanNY you was a hundred percent correct. That was the the problem the WHOLE DAMN TIME.....Thinking the tranny was bad I had the transmission rebuilt the person who rebuilt it didnt check the connection right and gave me the car back because he didnt realize the problem and gave me the car back stuck in INHIBIT MODE. Took it to somebody else and they check the wiring diagram and did a diagnostic test and BOOM problem corrected Plugs where switched and car runs great... Didnt need to rebuild the tranny but people fail to do proper diagnostic test anymore. Thanks for your insight Dan!!
Old Sep 20, 2013 | 02:05 PM
DanNY's Avatar
Ad·min·is·tra·tor
glad it worked out.
also check your shifter bushing. is the gear selector pretty loose feeling?
for the guys who keeps telling people to do a 5spd swap...IT'S NOT AS EASY AS YOU THINK!!! unless you have done it please don't tell ppl to go out and swap their autos for manual.
Old Feb 5, 2025 | 03:49 AM
tmille37@gmail.com's Avatar
Originally Posted by Maxima_Maima
Can please somebody help me on this...I have a 1993 Nissan Maxima GXE I recently had a motor swap to the car and all problems have began.. My main problem that I have it seems like my transmission.. The car seems like it’s stuck in 3rd or second gear because when I am at 45mph I am at 3000 Rpm but when Im at 60-65mph I am redlining. The transmission feels strong but I cant under stand why it wont shift. Also while in Park or Neutral the idle seems to be a bit high at almost a 2 RPM until I shift it in gear and it drops down to below a gran. Could it be that the TCU has gone bad? Has anybody had this problem and can help me with this issue?
I’m having the same issue but don’t know which plugin to switch around!
Lakersallday24
Nov 7, 2024 07:31 PM
Lakersallday24
Jun 16, 2019 01:35 AM
SmokinMax02
18
Sep 11, 2015 12:25 AM
Trin1j23
Aug 12, 2015 08:31 PM
