Jim Wolfe ECU or Apex'i S-AFC??
Old Jan 15, 2002 | 02:05 PM
Rancid90SE's Avatar
subject says it all? pros and cons of both??
BTW true that tuned stock ECU's no good for nitrous?
Old Jan 15, 2002 | 02:10 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: Jim Wolfe ECU or Apex'i S-AFC??
go with the ECU......on the VG it only possible to make remotely close gains if you have it professionally tuned(will require some $$) and include an ignition upgrade and advance the timing(17 degrees proved best on "Max O/Ds" VG), but even with all that the gains are still about 3-4hp shy of the JWT! so unless you like to fiddle around with stuff take the straight path and get the ECU, it costs less too!
Old Jan 15, 2002 | 02:16 PM
DA-MAX's Avatar
and yes a "tuned" ECU isn't for nitrous because it advances timing....but JWT makes a nitrous add-on($450) for their ECU unit that retards the timing accordingly when nitrous is in use and re-advances when nitrous is off!
Old Jan 15, 2002 | 02:18 PM
Rancid90SE's Avatar
providing all your info checks out ill go with the ECU
Old Jan 15, 2002 | 02:39 PM
DA-MAX's Avatar
and oh yeah, I wasn't so clear but I was talking about the AFC here-->
"on the VG it only possible to make remotely close gains if you have it professionally tuned(will require some $$) and include an ignition upgrade and advance the timing(17 degrees proved best on "Max O/Ds" VG), but even with all that the gains are still about 3-4hp shy of the JWT!"
Old Jan 15, 2002 | 05:34 PM
Rancid90SE's Avatar
yeah The JWT ecu is the way to go i guess...but must admit the S-AFC looks hot
Old Jan 15, 2002 | 05:42 PM
DA-MAX's Avatar
cool, cool! I'm going the other route though...the guys I talk to at Altered Atmosphere(shop around my way) have some tricks up their sleeve when it comes to tuning the AFC! I'm just gonna need some money for the dyno time....hope to go forth with this, this coming summer!
Old Jan 16, 2002 | 01:47 PM
Jason92SE's Avatar
APEXi all the way
the APEXi can be had for half the price and is adjustable!!Your call but I would not even consider the tuned ECU.
good luck
Jason
Old Jan 16, 2002 | 01:56 PM
DA-MAX's Avatar
Re: APEXi all the way
good luck
Jason
have you used the AFC before?? alone it will not EVEN come close to the JWT ECU on an N/A car without ignition tuning as well!!!!! the ECU tunes the ignition surve as well which the AFC DOES NOT!
Old Jan 16, 2002 | 02:07 PM
Rancid90SE's Avatar
well how about a AFC in conjunction with the APEX'i ITC (Iignition timing controller) which would be about the same price as the ECU,and far better tuning capabilities,am i right?
Old Jan 16, 2002 | 02:09 PM
DA-MAX's Avatar
ITC will not work on our cars, it was tried on Max O/D's VG....no go!!!! would be an awesome combo though!!
Old Jan 16, 2002 | 03:26 PM
Maximamike's Avatar
Call JWT(619-442-0680) and ask them about tuning their ECU better with an AFC. Bwahahahahaha..
Old Jan 16, 2002 | 03:32 PM
The Max's Avatar
Stock ECU's work just fine with nitrous.
I'm the proof of that (just look below ... no handbrake!) and have been for the past 3 years, albeit a dry shot. I recommend a wet shot plumbed directly into your intake plenum's runners.
Old Jan 16, 2002 | 03:39 PM
Rancid90SE's Avatar
WELL i got a 5speed,so would that work?
Old Jan 16, 2002 | 03:54 PM
DA-MAX's Avatar
doesn't matter, same ignition....no go!
Old Jan 17, 2002 | 06:57 PM
Rancid90SE's Avatar
well that pretty much blows
Old Jan 17, 2002 | 07:28 PM
DA-MAX's Avatar
yup the idea of being able to tailor your own igniton curve based on RPM is kinda cool....could have been possible to match or at least come close to what Jim Wolf has done, but thats a REAL longshot!!! but I always keep my eyes open for new gadgets though...
gigabyte
Jan 6, 2017 06:05 PM
Omar Abdurrahman Siddiqi
Aug 26, 2016 05:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
cruce91
Sep 20, 2015 10:23 AM
QueensMAX
Sep 15, 2015 04:14 AM
